Fuel injectors
Old May 12, 2003 | 10:36 PM
Psychostrkr's Avatar
Psychostrkr
Fuel injectors
Does anyone know the stock lbs./per hr and cc. flow of the fuel injectors in the 2000 Psd? Ford acts like it is a protected secret.I've spent alot more money than i wanted to on several manuals,that i thought for sure would cover this,of course they didn't.Any and all info on this would be much appreciated.
Old May 13, 2003 | 05:08 AM
Quadzilla's Avatar
Quadzilla
Fuel injectors
Here's some information from a friend's website:
The stock Ford injectors (94-97) flow 95 to 100 cc's on our flow bench.
The stock Ford injectors (99-01) flow 120 cc's on our flow bench.
The stage one injector’s flow 160 cc's (Stage 1 160 cc’s after 2600 rpm’s) Wide open throttle (WOT)
The stage two injector’s flow 160 cc's (Stage 2 160 cc’s after 2000 rpm’s. Mid range and up.
The H.O. International injectors 240cc's
The modified H.O. International injectors are flowing over 300 cc's
These test's are done at a 3000 rpm's, on a 1000 count test.
I hope this helps.
Old May 13, 2003 | 02:49 PM
Psychostrkr
Fuel injectors
Thanks alot Quad. If i could fax a six pack i would.Many thanks.
Old May 13, 2003 | 10:46 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Fuel injectors
530's???
