Sponsored by: Real Truck
ProComp = rough ride?
Old Aug 12, 2012 | 11:15 PM
obiwan kenobi's Avatar
obiwan kenobi
On my new to me 2003 F250 SD is a 6" ProComp lift kit, springs front and rear along with added blocks in the rear. I think the leaf count is 5.
I've read that > spring count = smoother ride, is this correct?
If it is who makes spring packs with > 5 springs?
Old Aug 13, 2012 | 12:58 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
There is MUCH more to springs than the number in a pack. Width, thickness, spring rate, etc.
Generally softer springs have a lower weight rating. Try to get these from the manufactures. However this is more of a guideline and not evidence to the stiffness of the spring itself; case in point: the new 2011 springs.
Old Aug 13, 2012 | 08:54 AM
bbender85's Avatar
bbender85
had a 4" pro comp on the red truck in my sig and it was stiff as a board. so much so that i totally removed the sway bar system and still had zero indication it wasn't there.
that being said i was not concerned with the ride back then. i loved bouncing around believe it or not lol. after 5 years it wore on me, and got to the point my wife wouldnt ride with my anymore.
Old Aug 13, 2012 | 12:13 PM
obiwan kenobi
Our drive back up Hwy 101 yesterday from Pismo Beach was no fun at all and, I'll be hard pressed to take the SD for our next trip, she'll want to take the Ex.
While there is nothing wrong with the Ex, it rides on stock tires, no lift, no OBA.
So the question stands, whose springs can I get to keep the ride height, load while smoothing out the ride and improving flex off road. There is no way this kit could do much off road (rock crawling) with the stiff springs.
Old Aug 13, 2012 | 12:15 PM
SuperDutyScaler's Avatar
SuperDutyScaler
first off what shocks are you running? the cheap 3000 series they give you with the lift kit? If so they are the worst shocks ever!
Old Aug 13, 2012 | 12:18 PM
bbender85's Avatar
bbender85
I started with the nitrogen 9000 series that came with the kit, then went to bilstein 5100's
Old Aug 13, 2012 | 12:23 PM
SuperDutyScaler
i have the Pro Comps diesel level springs on my 5.4 powered F350 with a set of sky jacker nitrogen shocks and my truck has never handled better, or driven smoother EVER. I think its your shocks first, and second you have a lift spring on your truck that has a huge amount or arch in it too provide lift, no lift spring is going to ride as good as a stock set of small arched leaf springs. A quality shock will make life much better but this aint no car, its a 3/4 ton truck
Old Aug 13, 2012 | 12:38 PM
obiwan kenobi
Pro Comp pro runner shocks which did improve the ride over the original shock
Old Aug 13, 2012 | 07:15 PM
SuperDutyScaler
so you put good pro comp's on which helped but the ride is still too harsh? Like i said your not gonna get a car like ride nomatter what you do, unless you do the 2011-up rear spring mod but then you loose half your payload capacity. No lifted truck wether its Ford or GM is gonna ride stock nice they all get harsher
Old Aug 13, 2012 | 07:18 PM
obiwan kenobi
Guess just used to my Jeeps with the coil springs, and half ton cap.
Old Aug 13, 2012 | 07:24 PM
Hotpocket's Avatar
Hotpocket
I have the same front leaves and shocks as SDscaler and it is 10x smoother then stock setup ..my truck used to remind me of driving a dump ruck with no air seat....so no procomp doesn't necessarily mean rough ride...
Old Aug 13, 2012 | 09:37 PM
Quad Racer's Avatar
Quad Racer
Super Duty = Rough ride. Good day.
jake_c_19
Jun 13, 2015 05:14 PM
hasteranger
Apr 27, 2012 06:14 PM
Redneckryder
16
Jan 7, 2011 08:47 AM
Overkill
Nov 12, 2007 08:34 PM
Shad's EX
Apr 10, 2006 12:27 AM
