MAP Sensor Check
Old May 22, 2003 | 04:50 PM
RangerRuss's Avatar
RangerRuss
MAP Sensor Check
I do indeed use K&N filters. I shall remove it, clean the MAF again and see what happens. I too have heard that the residue from these types of filters can or may cause a problem.
Another interesting phenomena: today at lunch hour I hooked up a Digital voltmeter to the TPS and drove to lunch. As reported earlier in this thread, the KOEO readings on the TPS were .85 volts at idle and 4.8 volts at full throttle (wide open). Well today while actually driving the truck, the readings were .91 volts at idle and 1.48 volts with the accelerator almost to the floor. Does this make sense to anyone? I struggle to understand why the voltage readings would be different KOEO and KOER on this application?
Thanks again for the advice on the K&N filtercharger and any other insight that can be provided.
Russ
cricketo99
18
Jan 31, 2024 04:15 AM
Mountain54
Mar 7, 2017 04:38 PM
neal2ross
16
Apr 6, 2016 08:11 PM
fenix1
Electrical Systems/Wiring
Jun 8, 2013 09:31 PM
pete17c
Feb 26, 2010 12:34 PM
