General Diesel Discussion
Diesel Engine Builders
Old Aug 12, 2012 | 02:17 PM
gckeith66's Avatar
gckeith66
Hi,
Does anyone know of a Diesel engine builder/ diesel crate engine supplier or have worked with one before? I don't have a core to provide so I'm looking for something drop in ready.
I found a company "The Horsepower Shop" out of Fairview, PA.
They have some set ups that I'd be interested in but can't find a ton of information on them besides on "Alibaba.com".
Thanks
Old Aug 18, 2012 | 03:47 PM
Maxium4x4's Avatar
Maxium4x4
Could you be more specific on what engine you are looking for?
Old Aug 18, 2012 | 04:54 PM
gckeith66's Avatar
gckeith66
Im not sure what direction i want to go in exactly yet but either the 98 - 02 7.3l powerstroke or cummins 5.9 common rail. preferably post 2004.5.
i am about an hour south of Sacramento and have hear some great things about Browns Diesel in riverdale but would like some more options.
Old Aug 18, 2012 | 06:17 PM
Maxium4x4's Avatar
Maxium4x4
I'll send someone in from around your area who may know what the better option would be. What truck are you looking to put the motor in, transmission you are hooking up to? My thinking, the Cummins does have the upper hand on after market parts and availability over the 7.3L
Old Aug 18, 2012 | 07:50 PM
gckeith66's Avatar
gckeith66
Thanks!
The truck is a '71 "High Boy". It had a 4 speed manual when I first got it, snapped the output shaft and destroyed the case so I swapped to a 3 sod auto that I already had.
I'd like a manual transmission again so I will most likely go that way. But I haven't looked into anything specific since I haven't chosen an engine.
I've been leaning towards the cummins (due to aftermarket availability, swap complexity and the weight savings) but I had an '02 7.3L Super Duty that, after a cold air intake and a more open exhaust, seemed to just crush all it's competitors, even the ones that had been chipped.
Old Aug 18, 2012 | 07:58 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
I've never heard anything bad about Brown's...if you don't mind a road trip there's Ponci's up in Fortuna if you decide to go with the 5.9.
Old Aug 18, 2012 | 08:10 PM
gckeith66's Avatar
gckeith66
Thanks for the info, is Ponci's a Cummins specialist in particular?
I think the plan will be to salvage an and have it gone through and replace anything too warn and address any know problems with that type of engine.
I've done quite a bit of gas engine work but know relatively nothing about the diesel engines.
Have you heard of anyone in Southern California?
I'll be station at Camp Pendleton in a few months.
Besides SoCal Diesel, I've heard great things but I believe they only do Duramax.
Again, thanks a lot for the help.
Old Aug 18, 2012 | 08:37 PM
SteveBricks
FTE Emeritus
Yes, Ponci's are Cummins guys. And yes, SoCal are Duramax specialists.
Here's a couple of Powerstroke guys that are very good, though they're not particularly close to Pendleton...but worth the drive IMO.
Loren Taylor: Welcome To DieselTech1.Com
John Ferguson: Domestic Diesel & Auto Service Chino, CA 91710
Old Aug 31, 2012 | 05:04 PM
'97f2507.3LBEAST's Avatar
'97f2507.3LBEAST
the only 7.3L crate motor i know of is the "black mamba" but the info is a little sketchy! if you really want a good high quality cummins crate engine, then check out, "Industrial Injection" they have a good selection of cummins crate engines! you can read their add in October 2012 edition of Diesel Power magazine. but heres the link directly to the crate engines.
Shop | Category: Cummins Crate Engines
this is the link directly to the cummins crate engines on their web page!
deereman4020
21
Feb 8, 2009 11:41 PM
dj1202
Mar 30, 2006 10:07 AM
Weasal42
Apr 29, 2004 05:27 PM
