Need some serious help.
Old Aug 12, 2012 | 09:16 AM
06LariatCC's Avatar
06LariatCC
Hey all. New to the forums, and this sucks to be my first post here.
I had to drive through a couple feet of water yesterday to make it home. Water wasn't past the middle of the hubs or anything, I'm on 35" tires and 2" leveling kit and 2" blocks in the back to keep the rake the same since I do tow.
Anyways, I parked the truck and came back out about an hour or so later and the Low Range and 4x4 lights were on even though I never shifted out of 2x4. I smelled something like really hot brakes, but thought someone drove through the water in a small truck and got the clutch hot. I tried the neutral foot on the brake thing and nothing would work.
Went back out this morning and played with it some more. Finally I popped the hood to check out the relays since it was mentioned here when I was browsing. I figured out what the smell was, and also why it won't change out of 4 Low. The relays somehow managed to get wet and shorted out. The entire relay block is melted and the wires going to it.
I'm supposed to tow my 24' trailer on Friday, so this has to get fixed. Are there any places you guys know of that would carry that harness? It goes from the relay box to the first (from the front) distribution block next to the driver battery to the transmission and transfer case. I'm terrified to price this from the dealer.
It's a 2006 F-250 Lariat Crew Cab 6.0L
If someone has it here, I'm a certified Paypal account holder and will pay to have it overnight shipped. Thanks all!
Here's the carnage:
Old Aug 12, 2012 | 10:55 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Wow, that sux! Wish I could help. Lucky that didn't flame up and make a much bigger problem. Any chance of scoring on in a local wrecking yard?
Old Aug 12, 2012 | 11:11 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Only OTHER guess would be the FORD dealer!
Old Aug 12, 2012 | 12:37 PM
06LariatCC's Avatar
06LariatCC
I'm not sure of any yards around here that have anything that new. I will try to find one for sure though.
Old Aug 12, 2012 | 01:32 PM
m-chan68's Avatar
m-chan68
Do you have a VIN you can post? You can PM me the VIN if you don't feel comfortable posting it publicly.
Old Aug 12, 2012 | 02:18 PM
mhatlen's Avatar
mhatlen
2006 Bullet-Riddled 6.0
I may be able to get you one of those, have acess to a couple of trucks w/blown 6.0 engines 05&06 will take a look. Mark
I just read it goes to transfer case??? The trucks I can get parts from are both 2 wheel drive. Please confirm it's a 4x4 only part. Mark.........
Old Aug 12, 2012 | 08:44 PM
9228.bobcat's Avatar
9228.bobcat
Go to carpart.com. they are basically all the junk yards on line. Thay will ship as well. Pay more for overnight but i am sure you can find something on there. Go to yhe last page that is darker and it will be cheapest. Might help. Get alot of parts that way.
Old Aug 12, 2012 | 10:51 PM
D Lambert's Avatar
D Lambert
Thumbs up Easy Fix
Get the numbers off the relays and you can purchase those at any automotive store. Pull the wiring out of the back of the hardshell and replace any burnt or melted connectors, plug them into the relays without the big plastic hardshell and make sure they go onto the same relay pin that you took out of the hardshell. Cover with some electrical tape untill you can locate the hardshell and you should be good to go. The hardshell is the big plastic square piece that holds the wiring in it's allocated spots.
Hope this helps.
Old Aug 14, 2012 | 07:17 PM
06LariatCC's Avatar
06LariatCC
Thanks for all the replies. It ended up being $160 from the dealer, which wasn't too awfully bad. I went ahead and ordered it and installed it today. Triple checked all the connectors and then reinstalled the battery.
Still stuck in 4 low. At least I know the harness is good. Anyone have any ideas as to why it may be still stuck in 4 low?
Anyone have a truck I can borrow for the weekend?
Old Aug 14, 2012 | 07:20 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Sure...just drop me a $25k deposit!
atomicglock
Dec 8, 2013 04:41 PM
jdecker88
30
Feb 26, 2010 08:04 PM
Prozon
Offroad & 4x4
31
Sep 24, 2008 09:26 PM
Greywolf
Tennessee Chapter
13
Apr 4, 2008 08:06 PM
snurtle112
Jan 7, 2008 01:40 PM
