Spark Plugs
Old May 12, 2003 | 08:18 PM
nhfire 77's Avatar
nhfire 77
Lightbulb Spark Plugs
Trying to find out if spending 8$ a plug for the Bosch +4 Platinum Plugs is worth it??? I could just stick with motorcraft but i want to use a high quality product, if it has redeeming qualities that justify $$. Any ideas
Thanks in advanace guys(or girls!)
98 Explorer EB 5.0
Old May 12, 2003 | 09:58 PM
c96drumm's Avatar
c96drumm
Spark Plugs
I put the +4s in my 96 302. Ran just as good with the motorcrafts, but the dealer is the only place I can find motorcraft around here, so the Bosches were quite a bit cheaper. In light of recent events, next time I'll be sure to buy American!
Old May 13, 2003 | 08:54 PM
devil421's Avatar
devil421
Spark Plugs
DO NOT PUT BOSCH PLUGS IN AN EXPLORER!
Buy the Autolite plugs that are recommended for your model of Explorer (platinum or double platinum). They are the exact same plug as the Motorcraft.
Old May 13, 2003 | 08:59 PM
nhfire 77's Avatar
nhfire 77
Spark Plugs
I am very happy with the idea of spending less $$$ But why not Bosch?
What is the drawback??
I'm not doubting you, I just want to be informed regarding my truck. BTW do you reccommend any particluar wire brand?
Old May 13, 2003 | 09:57 PM
dsmith1484's Avatar
dsmith1484
Spark Plugs
I put the bosh in my explorer and the following occured in less than 10 k
started to miss fire and lost a cylinder.
Pulled all plugs and found that the bosh plugs had gone way out of gap and even better was that I found one had a loose insulator. This was on the dead cylinder.
I also noticed that the performance was down with the bosh plugs as well as the MPG from the day I installed them. Even new the Bosh plugs only gave me 16-18 mpg with the Doubble platnum I get 20-22 and on one tank that was all highway I got 24 mpg!!!!!
I will never use the Bosh again in my explorer.
Hope this helps
Dean
Old May 13, 2003 | 10:18 PM
nhfire 77's Avatar
nhfire 77
Spark Plugs
thanks dean ill go with the autolite!
Old May 13, 2003 | 10:41 PM
SplashMan's Avatar
SplashMan
Spark Plugs
I used Bosh in my old X sport, now in my XLT and my wifes Focus... never had a problem and had 1 - 2 MPG gain. Nothing wrong with Bosh, they are a great plug. There going in my F-250 next week.
Old May 14, 2003 | 07:34 AM
devil421's Avatar
devil421
Spark Plugs
Bosch plugs will give rougher idle, loss of gas mileage and an overall poor driving performance. Of course it will be more obvious on some cars than others but its ALWAYS better to go with Motorcraft/Autolite plugs (not to mention Autolite double plats for my 99 Explorer SOHC are cheaper than the Bosch +4s).
Old May 14, 2003 | 09:03 AM
SplashMan's Avatar
SplashMan
Spark Plugs
Odd, just the opposite on my '99 Explorer XLT SOHC... better performance (drive and idle) and better MPG. Three of my friends ('01 Sport SOHC, '98 Sport OHV and '94 Limited 5.0) run the Bosch platinums and all of them had the same effects I did. They were actually the deciding factor in me getting mine. The Bosh were only $.12 more expensive than the Motorcraft/Autolite plugs here. As for the wire brand, I am running the Bosch wires too.
Old May 14, 2003 | 09:40 AM
devil421's Avatar
devil421
Spark Plugs
The thing is, you _may_ be overlooking the negative performance (positive expectancy). Go on over to www.flatratetech.com and check the Ford Owners Support forum. There are several recent threads regarding the use of Bosch plugs in Fords. Most ASE Ford techs recommend NOT using them. Take a look, some interesting insights.
Old May 14, 2003 | 09:50 AM
nhfire 77's Avatar
nhfire 77
Spark Plugs
I thionk im gonna set up a poll a see what people think i thank all of you for your imput. im not decided now!!!!
Old May 14, 2003 | 10:31 AM
SplashMan's Avatar
SplashMan
Spark Plugs
Since I guess I am "overlooking" how my vehicle that I have driven and worked on for 76,000 trouble-free miles is performing I'm going to leave this thread with this last bit of info for nhfire 77...
There is about a 50/50 split on the plugs over there and there is a lot of good and bad info about them. General consensus it to stay away from the +4, but the rest of the Bosch line up is fine. I am on my second set of Bosch Platinums (change every 30,000) and have had no problems and a mild MPG gain. I hope I can "overlook" the same effects on my F-250 when I put them in it this weekend.
Ultimately, it is up to you, research... then buy... you can't go wrong. Good luck.
Old May 14, 2003 | 10:44 AM
c96drumm's Avatar
c96drumm
Spark Plugs
Maybe you should compromise and go with Champion!
Old May 14, 2003 | 10:58 AM
devil421's Avatar
devil421
Spark Plugs
I had no intention of insulting. What I meant was that sometimes things can appear better than they really are.
I went through that with the Bosch plugs but after hearing what happens with those plugs, I DID start to notice the rougher, loopey idle and I realized why my gas mileage had been going down. I didnt even think to attribute it to the plugs eventhough it did start right after installing them. I recently swapped in Autolite APP103 double plats and the idle returned to it's normal, solid rpm and the gas mileage went back up a few mpg.
The point was that sometimes performance losses are overlooked or not realized, either on purpose or by accident.
Either way, from what Ive seen the consensus is to stick with OEM plugs for best performance (Motorcraft/Autolite).
Old May 14, 2003 | 11:25 AM
nhfire 77's Avatar
nhfire 77
Spark Plugs
WHOA
Were here to help not to hurt!!! I appreciate no one "overlooking" any details. So i will thank you all for such passions about this.
