V10 threw fault code
Old Aug 9, 2012 | 04:34 PM
martyhpatrick's Avatar
martyhpatrick
I got a check eng light and read the codes. Cam sensor, misfire 5 & 8. Replaced cam sensor. Got light twice more. Cam sensor. Cleared codes, now no light but, I lost bottom & mid range HP at a steady decline. Run like a scalded dog on top end. Replaced fuel filter on frame rail & air filter. No cure. Noticed dash dim when headlights turned on. Pulled pos battery cable engine died. Replaced alt old one tested good. Drove to parking spot no power damn near couldn't pull it self. Turned off wouldn't start. Before I turned off it would rev up perfect just no power to move. Had a camed up sound at an idle like a slight miss. No fault codes present. Ford claims crank sensor. Haven't replaced that yet. Have fuel in fuel rails. 10 coils could not have lost spark at once. Any ideas other than crank sensor?
Old Aug 9, 2012 | 04:46 PM
Monsta's Avatar
Monsta
Sit. Stay.
Multiple cylinder miss? Sounds like more COPs are bad. Would explain the loss of power... Most times COPs won't throw a code.
Never heard of a no start due to it though...
Old Aug 9, 2012 | 05:48 PM
martyhpatrick
COP? Coil Over plug?
Old Aug 9, 2012 | 06:44 PM
TrdLtly's Avatar
TrdLtly
TreadLightly
Yes that is correct.
Old Aug 10, 2012 | 09:01 AM
jh818's Avatar
jh818
What about wire connection on cam sensor?
Old Aug 10, 2012 | 09:05 AM
martyhpatrick
Unplugged checked twice.
Old Aug 10, 2012 | 03:02 PM
Monsta's Avatar
Monsta
Sit. Stay.
Any issue with the cam or crank sensor is gonna set a code.
Can you check #5 & #8 coils?
Old Aug 10, 2012 | 04:05 PM
martyhpatrick
Ford claims @ times crank sensor won't throw code. Got new one will install today. Cross fingers
Old Aug 10, 2012 | 08:54 PM
martyhpatrick
New crank sensor no start. Fuel pump cycles. New crank and cam sensors. No fault codes. Poured gas into throttle body no fire. Any ideas?
Old Aug 10, 2012 | 11:55 PM
wpnaes's Avatar
wpnaes
Clogged cat?
Old Aug 11, 2012 | 02:00 AM
jh818's Avatar
jh818
What's your fuel pressure?
Old Aug 11, 2012 | 09:56 AM
martyhpatrick
Don't no that fuel pressure would be the issue. I sprayed fuel in the throttle body as I cranked it no fire or even try. Is there a fuse able link from the ignition to the coils?
Old Aug 11, 2012 | 10:16 AM
TrdLtly's Avatar
TrdLtly
TreadLightly
From my understanding of a fuel injection system: Without fuel pressure the injectors will not atomize the fuel therefore you will not get fuel to the cylinders. Have to have fuel pressure to "push" the fuel through the injectors. A light amount of starting fluid might help as it is atomized already, but no matter how much fuel you dump down the throttle body it will not supply the necessary pressure.
Old Aug 11, 2012 | 10:19 AM
martyhpatrick
Good point I will get a pressure checker and see how much psi I got.
Old Aug 11, 2012 | 10:23 AM
TrdLtly's Avatar
TrdLtly
TreadLightly
You might check your fuel pump fuse. Check your owners manual (electronic owners manual) That is quick, easy and cheap. Let us know what you find.
