Power steering box
Old Aug 9, 2012 | 07:14 AM
Rus01's Avatar
Rus01
Power steering box
How can I get the play outa the power steering box? I have a 2001 F350 super duty diesel with a 7.3ltr
Old Aug 9, 2012 | 08:02 AM
rtazz17's Avatar
rtazz17
There is an adjustment on the box but most of the time even if that helps its only temperary.I believe if you are looking up from the bottom of truck at steering box the adjustment is on bottom of box.Is everything else tight on your front end?tie rods,ball joints ect?its usually a combo of everything making front end loose.If you need a new box,red head steering is my suggestion to get one.Lots of guys have used them.I did as well and it made my steering much better,but I also replaced everything else in the front end due to worn parts.If you over adjust the steering box you could make it stick in one direction or the other.Meaning when you come around a corner it doesnt return to center and you keep turning.Adjust it in 1/4 turns and take it for a ride.
Old Aug 9, 2012 | 11:22 AM
Rus01's Avatar
Rus01
Ok thanks! I will try that first. Everything else looks tight in the front end
Old Aug 9, 2012 | 11:43 AM
CSIPSD's Avatar
CSIPSD
Its on the top of the box... I dont have a picture of it, but it can help for a bit... Mine lasted about another 10-12k before I replaced the box.
Old Aug 9, 2012 | 12:02 PM
microdevil45's Avatar
microdevil45
That is an interesting avatar you have there CSIPSD!
Old Aug 9, 2012 | 01:01 PM
pin8246's Avatar
pin8246
I was thinking about doing this today since I have to straighten out my steering wheel. But I dont know if mine is play, or just me not being used to having oversized tires on anything.
Old Aug 9, 2012 | 07:45 PM
rtazz17's Avatar
rtazz17
I stand corrected..its been a while..I swear I was on my back when I adjusted mine ...
JCastellaw
1966 - 1977 Early Broncos
Jan 7, 2008 11:43 AM
RedDawg
Aug 24, 2005 09:48 PM
