Swapping A/C.
Old May 12, 2003 | 05:02 PM
desperado_18_2000's Avatar
desperado_18_2000
Swapping A/C.
I've got a spare 82 F-150 300 with factory air, and i plan on swapping it onto my truck later this summer.
Aside from getting it recharged and the seals replaced, what will i have to do, to make it work on my truck?
My current Daily Driver, is also an 82 F-150, 300 six, that originally had factory air.
I'm assuming i'll need to swap the heater box out, and add all the parts i'm missing?
Any help is appreciated.
Old May 13, 2003 | 12:03 AM
steve83's Avatar
steve83
Question Swapping A/C.
If they BOTH had factory air, why would you need to swap anything?
Old May 13, 2003 | 12:35 AM
desperado_18_2000
Swapping A/C.
The reason for the swap is, my truck has had all of the factory air peices removed...it has a stock heat only heater box, the a/c core is removed and the compressor is long gone, along with the lines or anything else that i could use for the a/c system.
Now the other truck, has all of these parts, and they are in good shape... all it will need is a recharge of some 134 I'd assume.
Old May 13, 2003 | 12:41 AM
steve83's Avatar
steve83
Swapping A/C.
Make sure you check out the wiring, vacuum, and control panel, too.
Old May 13, 2003 | 01:26 AM
desperado_18_2000
Swapping A/C.
Thanks steve!
I'll check on all of that shortly.
