Betty turns oil burner
#331
How much room back and forth do the mounts from Chase allow you to move the engine? I know the goal was to have mounts that bolted to original location so very curious about the amount of free-play left in that respect.
And I would assume the lateral mounting distance is fixed as they were pre cut, unless he left additional material on for individual application? In my personal application I am a little concerned with how I am going to fit the intercooler behind the grill with the way it mounts (my cab is a Bumpside)... should be interesting when I get there, just hoping there is enough room so that I can keep an unmodified appearance to the front end.
Now back to the thread at hand. Looking GOOD Brandon. I wish mine was going through this much detail. With how much fab I was doing on the truck I was just gonna run the motor as-is for a while & hope it's as good as the seller claimed...
Man I wish I could get back to work on mine, but seems it will be a few months...
Also - safe to assume the "silver" parts on the motor are cleaned up, wire wheeled and clear coated? Love the look - how'd you do it?
#332
Without that O-ring it would leak coolant all over the place. I'm not sure what O-ring you are referring too. I have absolutely no smog or EPA parts on this engine.
#333
Also thanks everyone for the kind words.
I have a little bit more to do then it's save up time for the actual swap. I still need to buy an air dog, injectors, turbo, radiator, fuel tank, starter, alternator, batteries Etc. Plus I'm sure a couple hundred dollars in nickel and dime crap.
#335
Yep!! They still do both zinc and cad. It's metal finishing group in Sacramento. I didn't think I'd find a place either that still did cad but luckily I did. Especially since cad is way more corrosion resistant than zinc.
#336
If you don't mind too much, how much was it to get that lot plated? I used to have a guy down here in the Bay Area that did CAD but it seems he had been out of business for a few years when I got back from England.
#338
It was $150.00 for the bolts and brackets and $250.00 for the rest. Considering all new metric bolts already zinc plated would have been way over $400.00. Not bad in my book.
#339
That sir is a damn fine deal, I will most def be giving them a call! Thanks for the info, reps your way
#340
#341
#342
Small update for this weekend. I got the O-ring I needed, and got the water inlet all buttoned up.
After that the belt tensioner.
Got the valve covers painted. Except for the 4bt oil fill cover. I ended up ordering a 6bt industrial cover as the bolt holes are further inset for some reason on the cover I have. I'll have the new cover by weeks end then those can go on.
This is how she sits. I have to put on the fuel pump block off, and the valve covers. Then it's waiting for money time.
#343
#344
I'm telling you, I am itching to yank that 460 out. Unfortunately, I need to get a few more parts before ill do that. My plan is to have as many parts as I can think of bought and ready to go. Then I'll strip her down and get to work. I want to keep the down time as short as possible.
#345
With the extensive masking you are doing on some things I'm surprised what you don't mask off, like the inside of the water neck, do you plan on running a coolant filter for when the paint comes off and into the coolant system?
I image with the great quality of work and extra efforts on appearance that you will be heavily cleaning and painting/coating inside the engine compartment while there's nothing in there? I used Duplicolor Undercoat on the firewall when the engine bay was empty, seems to be holding up great, looks pretty good and was a very minimal improvement in sound/heat insulation. Cost me about $10 as compared to the much more expensive Lizard Skin and other brands.
Kind of a ramble and unfortunately I routinely fail at picture posts so that drags out explanations.
