2000 EXPY electrical problem
Old May 12, 2003 | 04:06 PM
graftx's Avatar
graftx
Hi guys, new to forum here! A few months ago after not having started my EXPY for a week, I went out to start it and it just clicked. It would not do anything other than click when the cables were hooked up to jump it. It took about 5 minutes of charging when we jumped it off of another vehicle to get it to turn over. It then started with no other problems until this morning(Monday morning). It had been parked since Friday evening. My wife tried to start it and it just clicked, and we jumped it with the same results as stated earlier. I took it to the local auto parts store and tested it and the tester said everything was normal.
graftx's Avatar
graftx
any thoughts/suggestions?
Old May 12, 2003 | 07:19 PM
deanjet's Avatar
deanjet
What kind of test did they do? I think I would start with a load test on the battery...
Old May 13, 2003 | 12:16 AM
graftx's Avatar
graftx
they did a load test on the battery, and then tested the whole electrical system
Old May 13, 2003 | 06:06 AM
1999XLT's Avatar
1999XLT
Try hooking up a scan tool and see if it throws any codes. If the auto parts store did it did they get any codes back?
Old May 13, 2003 | 10:02 AM
graftx's Avatar
graftx
they hooked up some tester to the battery and it said the battery was good, as was the rest of the electrical system.
Old May 13, 2003 | 04:41 PM
blow's Avatar
blow
Have you had any rain recently. My 2000 Expy did the same thing a couple of weeks ago. Seems that the windshields develop a leak and drips water on the GEM module. This causes all kinds of electrical things to pop up, like the heater fan to come on in the middle of the night and drain the battery down. Just a thought.
Old May 14, 2003 | 12:55 AM
graftx's Avatar
graftx
that is a thought. . . .i am figuring that there is something pullin juice off the battery that i don't know about that runs it down in a few days.
Old May 19, 2003 | 07:49 PM
tyger25's Avatar
tyger25
Hey, don't know if you figured out your problem or not yet, but I had the same problem. I was cleaning it out, listening to the radio one night, and then went to bed when I was done. The next morning, it just clicked when I tried to start it. I jumped it, and it was fine til I turned off the ignition, then I couldn't start it again. I took the battery in the A-Zone, and they said it was fine. I took the battery then to Advanced Auto, and they too said it was fine. So, I went to Wal-Mart and bought a new battery just to compare, and now no more problems.
Old May 20, 2003 | 09:15 AM
slcompton's Avatar
slcompton
More than likely, you were experiencing oxidation on the positive battery terminal. I had this happen all the time on my '93 Exploder. About every 3-4 months I would have to clean off the deposits on the battery terminals (the positive was always the worst). Finally, a mechanic who sold me the Interstate battery recommended putting conductive grease on the terminals.
I used some regular joint grease, and never had a problem again for 3 1/2 years.
Drug the Exploder to the dealer last week and got a 2000 F-150 XLT -- AHHHH what a feeling to be back in a truck!
slc
