97 460 CC Diesel Conversion with a 24V OR 03+ CR
on
1 Post
I had considered doing a 12v in my cc originally. Check this site fordcummins.com - Increase Horsepower with Ford Cummins Diesel conversion kits. For $25 you can order their install instructions. It tells you everything you need to know. I know the trans crossmember has to be moved back 2 or 3 inches, and the drive shafts will have to be cut to fit if you keep the fan on the engine, which they recommend you do.
Heres a forum for Cummins conversions: Cummins Conversions - Shop Talk - Tools - Fabrication - Dodge Cummins Diesel Forum
As a matter of fact, i just found this. Over 50 pages of detailed, step by step, and every problem he ran into swapping a 01 CR into a 93. Here she is, i think this is what your looking for. Ive learned more than i thought i would by page 5.
1993 Ford 24v Cummins crew cab - Page 5 - Dodge Cummins Diesel Forum
ffactor01
13
01-21-2011 05:43 PM
