Final drive is too steep
Old Aug 4, 2012 | 09:26 PM
copracr's Avatar
copracr
I'm turning a little over 2300 going 70mph with a 4.30 rear gear and 31.5" overall tire height. Since I'm seeing about 16mpg city and 16mpg highway I feel like i'm spinning the motor past it's "happy spot" on the highway.
I'm wondering what rpm is the best to be at and if a tire change can get me there?
I would swap the gear but it's a 4x4 so that a little expensive changing 2 sets and I need rubber anyways.
2000 Excursion, E99 7.3L, 2000 4r100, 4x4
Old Aug 4, 2012 | 11:35 PM
Monsta's Avatar
Monsta
Sit. Stay.
Somebody changed it to 4.30s as PSD Excursion were only available with 3.73.
IMO you should be around 2000rpm at 70mph...unless you tow heavy. A tire change could put you there but you'll be running 35s.
Some 295/75R16s would split the difference with a calculated RPM at 70 of 2180. And they should fit on your stock rims without too much effort.
Old Aug 5, 2012 | 03:35 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
you sure you have 4.30's?
could someone have thrown v-10 axles under there?
I'd shoot for a 33" or 34" diameter. that'd slow down the tire speed and lower the highway RPMs. not to mention look better
Old Aug 5, 2012 | 11:18 AM
copracr's Avatar
copracr
You guys are sharp. This was a v10 Ex I put a 7.3 in. Would a 33/34 diameter be enough?
Old Aug 5, 2012 | 02:47 PM
Monsta's Avatar
Monsta
Sit. Stay.
The 295s I suggested are 33.4".
Old Aug 5, 2012 | 08:10 PM
copracr's Avatar
copracr
I forgot about having a couple of mustang buddies from back in the day and they regularly swap out gears/tires and use online calculators to figure out where they're at. I got a link to a calculator:
Tire Size Calculator
I plugged in my numbers into the very bottom calculator and it was pretty close: it said I have a 30.8 inch tire now and it's 31.25. I know my speedo under-reports a little anyways cause I just drove to N carolina and watched the mile markers.
After I put in the same 2330 rpm but moved the speed up to 80 instead of 70 it said I'd need a 35.2 inch tire. I have 18x10" rims but that's still a lot of sidewall for a highway vehicle. Do any of the new trucks come with tires that big?
harley4jcs
Jan 22, 2015 09:39 PM
Telsmith
Dec 23, 2014 08:24 AM
rvpuller
6.2L V8
Mar 16, 2012 07:36 AM
ggadwa
May 4, 2006 12:33 PM
SLE
Modular V10 (6.8l)
42
May 29, 2005 10:12 AM
