2013 Ford F150FX4 Max towing mirrors
Old 08-13-2012, 07:27 PM
mrford49's Avatar
mrford49
mrford49 is offline
Talking 2013 Ford F150FX4 Max towing mirrors
Does anyone know how to find the part numbers for the 2013 f150 FX4 power fold,power telescoping with power glass heat turn signal and security approach lamps with black caps. And will they fit my 2012 F150 FX4 with standard power folding and power glass heat with turn signal indicator and security approach lamps with white caps. I do have the ording paper work from Ford for the 2013 Ford F150 FX4 max towing package numbers. It is the 402a Optional Equipment group.It also list it under Option code 60P. I believe they will interchange because all the other mirrors are still listed for the 2013 FX4 all the way back to the 2007 FX4 F150. I need the part numbers only. No problems since I have owned the truck since April 2012 and almost 10,000 miles on it. Thanks for your help. Ron
Old 08-14-2012, 07:56 AM
juneau76's Avatar
juneau76
juneau76 is offline
Maybe Parts Guy Ed can help you with that. They should fit in terms of mounting, but I can't say anything about the wiring, power stuff, etc.
Old 08-15-2012, 03:27 AM
Watt-maker's Avatar
Watt-maker
Watt-maker is offline
When you find the numbers, please post them up.
highkrausen
2015 - 2020 F150
08-16-2019 09:23 PM
Steve56
1999 to 2016 Super Duty
27
06-22-2019 03:30 AM
Bctanker
2009 - 2014 F150
04-29-2015 09:20 PM
19expy97
2004 - 2008 F150
17
10-20-2011 07:14 PM
Ranger1F150
06-11-2008 06:07 PM
Quick Reply: 2013 Ford F150FX4 Max towing mirrors
