Sponsored by: Real Truck
Bought a 2003, need some advice
Old Aug 3, 2012 | 02:38 PM
mikec3500's Avatar
mikec3500
I just bought a 2003 v10 f250 with 94,000 miles. Looks new inside and out. I am excited to move up to a real truck. I have a couple of questions. The rear differential cover is leaking and the truck seems to bounce a little more than my other 1/2 trucks. Would the rear leak be covered under warranty? Also, the truck did not come with a wireless entry key fob, not sure if it originally had wireless entry. How can I check? I also need to purchase a set of running boards, anyone have any good suggestions? The truck is like an electric blue color with a silver lower stripe. Thanks for any advice.
Old Aug 3, 2012 | 03:12 PM
temperoath's Avatar
temperoath
Congrats. I actually just bought an '04 F250 6.0.
If you got a warranty (if you bought from a dealer, or if there is some kind of extended warranty) the diff leak may be covered, unless they open it up and find that it was do to owner negligence. If the diff and mating surface is not damaged, you can probably fix it yourself fairly easily. By bounce, do you mean stiff, as in you feel more bumps? If so, its probably just due to a bit beefier suspension. As long as it doesnt feel isolated to a certain part of the truch, you just have to get used to having a tougher truck! Mine didnt come with keyless entry either, but if you have electronic locks, you can have one installed, even by doing it yourself for pretty cheap.
Good luck!
Old Aug 3, 2012 | 04:37 PM
MikeC501's Avatar
MikeC501
sounds like a nice truck.
Boaterguy
May 10, 2016 11:48 AM
banginona40
Oct 20, 2007 06:06 PM
wanabe2
May 19, 2006 11:55 AM
couleeman
1997 - 2003 F150
Dec 21, 2005 05:23 PM
Fxxer
1997 - 2003 F150
Aug 24, 2005 09:54 PM
