3 speed conversion
Old Aug 3, 2012 | 05:50 AM
Thinlizzy13's Avatar
Thinlizzy13
3 speed conversion
Does anyone know of a good conversion kit for a 3 speed on the floor? my truck has a 352 V8 and I bought it with it converted to a floor shift, but the previous owner did a really shoddy homemade job. The gears are pretty much in a backwards shifting order on the stick, it has a lot of play, and often misses 3rd gear, or gets stuck between gears. I was just wondering if anyone has done this and found a decent conversion kit that's tighter and with shorter shifting distance? Any input would be greatly appreciated.
Old Aug 3, 2012 | 12:01 PM
StevenhF100's Avatar
StevenhF100
The Hurst Mastershift 3 sp works very well. Don't know how availble the installation kit is, but I mounted one on the cheapy mounting kit and it worked fine.
Old Aug 3, 2012 | 12:52 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
The Hurst or Lokar are the only good options I know of.
Old Aug 3, 2012 | 05:36 PM
jowilker's Avatar
jowilker
TL, Welcome to FTE and the Slicks forum. Don't know how much hanging around you have done, but want to offer a question.
Have you thought about the power disc brake & steering upgrade? You would be swapping a steering column with that upgrade. Might shoot a couple bids with that shot.
John
Old Aug 3, 2012 | 09:20 PM
LITTLE BLACK TRUCK's Avatar
LITTLE BLACK TRUCK
You gotta flip the arms on the transmission, on a 3 on the tree they point down I think and on a floor shift they gotta be pointing up. might have that backwards, but flip the arms and the shift pattern will be normal.
JRB64
19
Aug 15, 2018 10:45 AM
70farmtruck
Aug 6, 2015 01:10 PM
JeffXP
Feb 10, 2004 09:01 AM
kwt
Dec 30, 2003 11:20 AM
