Is it possible to get the oil pan out without removing the motor? It looks to be really close if I jack the motor up all the way, but I just wanted to see if an of you guys have got away with it.
It is doable. By the time you get the engine high enough to get the pan off, there's not much left to unhook and just pull the engine out.
Granted, it is a bit easier than doing this same task on a 79 or older 2wd, as they have a front sump pan that sits right above the crossmember........
