Check your IWEs are disengaging
Old 08-01-2012, 12:32 PM
edwardlloyd's Avatar
edwardlloyd
edwardlloyd is offline
I reckon I must have been driving over a year with engaged IWEs. You just don't know. I checked recently when I had the truck on the lift. You really should check for this everytime you get the chance.
With the wheels is the air run the engine (in 2WD). Turn the front wheels by hand and look to see whether the front driveshafts are turning. If they are your IWEs (vacuum operated front hub engagers) are not functioning.
Twas just the little valve which gets wet. $35 later I'm on the road with less wear to my front end components and better fuel economy.
Ed
Old 08-01-2012, 09:10 PM
02transam's Avatar
02transam
02transam is offline
Thanks for the info! Will check mine when I get a chance!
Old 08-01-2012, 09:38 PM
GwarForAll1021's Avatar
GwarForAll1021
GwarForAll1021 is offline
I tied some extra long zip ties onto my front drive axles. You can hear them slap the chassis when they turn. It helps if your experiencing a small leak that you lose vacuume when driving but not at cruising speeds.
Old 08-01-2012, 10:36 PM
bigunit54's Avatar
bigunit54
bigunit54 is offline
I put a chalk line on my front drive shaft once to check, drove around a while checked it and it hadn't moved, that is something you can do to check also.
Old 08-02-2012, 11:51 AM
edwardlloyd
All good ideas. Folks just need to know. There must be thousands of trucks driving around with engaged IWEs and the owners just don't know.
Ed
Old 08-03-2012, 02:59 PM
ChrisCarter's Avatar
ChrisCarter
ChrisCarter is offline
If its a small vacuum leak it'll engage/disengage half way and tear up stuff. I found this out myself. The iwe wheel end hubs are 82 bucks on tousleyfordparts.com, anywhere else they are 110+ Dealer wants 124 a piece for them. I just ordered one for my driver side as I replaced the pass side a few months ago back in the winter months. The seals blow out and they don't hold vacuum like they are suppose to. I've got vacuum hose taped off and closed up so it'll stay engaged on the one side and won't mess something up till the new part gets in. You can hear the axle turning going down the road they do make a small sound as it turns...
Old 08-07-2012, 07:32 PM
fordman19762003's Avatar
fordman19762003
fordman19762003 is offline
I've always thought about disconnecting the vaccuum system so the front end stays locked in. The small amount of extra fuel and wear this would cause would be worth it not having to worry about all the issues with this system.
Old 08-07-2012, 09:46 PM
02transam's Avatar
02transam
checked mine and the are working just fine..... I guess the crap mileage is due to the 305/65/18s and 2" level. lol
Arthur Ahearn
04-23-2014 06:52 AM
JP2085
2004 - 2008 F150
06-24-2010 02:40 PM
970mmj
1997-2006 Expedition & Navigator
21
12-21-2009 09:49 PM
dnelson82
03-27-2006 11:12 PM
whistler
05-10-2002 10:01 PM
Quick Reply: Check your IWEs are disengaging
