Help With Identifying Under-Hood Items
Old Aug 1, 2012 | 12:02 PM
Grogan-14's Avatar
Grogan-14
I was hoping one of you kind gents might help me with identifying several items under the hood of the '92 F150 XLT 4x4 I recently purchased.
These unplugged connectors are both male. The black one comes out of the power distribution box, while the grey ones runs down under the truck:
Old Aug 1, 2012 | 12:11 PM
Grogan-14's Avatar
Grogan-14
And this, which is located over at the driver's side fender. The hose that's on there comes from off of the exhaust manifold. I'm wondering what else should be connected there?
Old Aug 1, 2012 | 12:18 PM
dixie460's Avatar
dixie460
Dunno bout tbe electrical connectors, but I can look at my 96 later if nobody comes up with anything. Its probably different though.
That second picture looks like part of the smog pump system.
White 97 xlt's Avatar
White 97 xlt
Nothing else connects there,, that is a muffler for the air (smog) pump
Old Aug 1, 2012 | 12:31 PM
Grogan-14's Avatar
Grogan-14
Thanks for the quick replies!
I was hoping as much. We have only visible emissions inspection on pre-OBDII here, so I just wanted to make sure it wasn't something I had to worry about.
Old Aug 1, 2012 | 01:08 PM
niner's Avatar
niner
Oh, one I know! The electrical connections are where you plug in a relay block to power the aux and backup light functions of the 7-way trailer plug that you can install. You should have two similar plugs back behind the spare tire. I discovered that my truck was prewired for a 7-way plug when I went to go add one - previous owner had spliced in a 4-flat plug already.
You can search for Ford part #14A346 - Auxiliary Battery Wiring Harness to find one. I ended up skipping it - my trailer needed the brake controller, but not backup lights or aux power.
Old Aug 1, 2012 | 01:16 PM
Grogan-14's Avatar
Grogan-14
Thanks, niner!
I had just been checking the 7-pin outlet earlier, and had noted that I had no auxiliary power available there, though the standard functions all work. That explains it. My trailer requires a 4-flat, and I figure I'll just get an adapter for $10 or so.
mcali2
Aug 28, 2018 11:10 AM
Phased3
Large Truck
Oct 25, 2015 07:56 PM
handyjohn
Aug 10, 2014 12:54 PM
Austin J.
Feb 12, 2013 11:39 PM
1964Goat
17
Mar 27, 2012 11:27 PM
