oil leak
Old Jul 30, 2012 | 04:31 PM
beaver77's Avatar
beaver77
oil leak
I got 76 360 its leaking oil up at the top of engine in the rear. Ihave put intake gaskets and valve cover gaskets on it, sitting idleing it dosent leak at all but after driving for a while its got oil leaking down bellhousing, cant quite figure out where its coming from any ideas would be great
Old Jul 30, 2012 | 04:49 PM
jowilker's Avatar
jowilker
beaver77, I can feel your pain. Just because you did those things doesn't mean you corrected the issues. So you will know our trucks have a huge opening that air rushes in and blows oil down the back of the engine and onto the driveway.
This is a huge known issue, replacing the heavy intake you can knock things out of place that you thought were secure. The valve covers need to be blocked to return the bolt hole area back to absolutely flat before install. The valve covers need to be tightened to about 15 inch pounds, barely snug.
There are other techniques that I'm sure others will share.
John
Old Jul 30, 2012 | 08:41 PM
bamaf150's Avatar
bamaf150
Mine has some very minor oil leaks as well, they all tend to end up on the bottom of the bellhousing or the tranny so unless its really bad I'm not worried about it. I have never seen an FE with any age on it that didnt weep some oil anyways. Yours does sound like valve cover leaks though, as said, overtightening is usually the culprit. Many here also advise to make sure the oil return passages under the covers arent blocked as they will pool oil in under the cover then leak.
Doctomario777
1983 - 2012 Ranger & B-Series
Mar 22, 2013 03:20 PM
mv1967
May 10, 2010 08:20 PM
inline_6
May 30, 2007 03:56 AM
88bronk
1978 - 1996 Big Bronco
Mar 13, 2004 11:59 AM
desperado_18_2000
Mar 12, 2001 08:45 PM
