tank capacity
Old Jul 27, 2012 | 04:31 PM
scardina61's Avatar
scardina61
tank capacity
Hello, in trying to figure my mpg, for troubleshooting reasons, what is the capacity of the front and the rear tank on a 95, era f150? Thanks
Old Jul 27, 2012 | 05:27 PM
bashby's Avatar
bashby
I think... Short wheelbase 16 ft/ 19 rear, long Wb 19/19. Got your owners manual?
Old Jul 27, 2012 | 08:43 PM
fordka's Avatar
fordka
rear tank is always 18 gal. side mount on short bed is 16 gal and long bed side mount is 19 gal
Old Jul 30, 2012 | 07:05 AM
scardina61's Avatar
scardina61
Ok, so far i have 145 miles on the front tank. It hadn't ruin dry yet but it's about to. That's less than ten miles a gallon. Even with 285 tires that seems way low. About half of that was pulling a small trailer with a four Wheeler. That shouldn't be that much of a load at all.there had got to be something else going on. Agree/disagree????
Old Jul 30, 2012 | 08:03 AM
jroehl's Avatar
jroehl
You don't know until it's empty and you've refilled it.
Jason
Old Jul 30, 2012 | 08:16 AM
882tank's Avatar
882tank
The gas gauges in these trucks are notorious for being inaccurate. You need to go by miles driven and ignore the gauge for the most part.
Old Jul 30, 2012 | 08:24 AM
rla2005's Avatar
rla2005
Fill up the front tank then make your calculations based on how many gallons it takes to fill it back up. The fuel gauges on these trucks can be very inaccurate.
BTW...the front tank on my old 1992 F350 4x4 held 17 gallons. The rear tank 19. The rear tank would register below E after 14 gallons were consumed.
Old Jul 30, 2012 | 08:46 AM
scardina61's Avatar
scardina61
Ok good to know, i topped off the front then started keeping tabs, i will go ahead and run it dry before i total it all up, also i plan to do this about the times so i can get a good average
Old Jul 30, 2012 | 09:28 AM
bashby's Avatar
bashby
Yep, need to do several tanks and average it. You should also check the accuracy of your speedo/ odometer.
Marty9987
Mar 10, 2015 09:50 PM
dgmontoya
Sep 24, 2010 11:19 AM
KingRanch250
6.4L Power Stroke Diesel
Mar 10, 2008 04:29 PM
oldfrt84
Feb 1, 2008 11:41 PM
fordguy300
Dec 4, 2007 06:42 PM
