I rinsed the engine off while running and now she won't start by key. Will start if I jump by cylinoide. Checked all fuses, relays, changed cylinoide, let dry for couple days. When I turn the key it does nothing! Starter is new! Any suggestions would be helpful!
seems like you got some water in a plug somewhere maybe try blowing out all the electrical conections with air, or spray some crc on the electrical conections to disperse any moisture
