"Miles to Empty"
Old Jul 27, 2012 | 07:57 AM
FORD OR DIE's Avatar
FORD OR DIE
"Miles to Empty"
Any body know how accurate it is? Thanks
Old Jul 27, 2012 | 08:07 AM
shortride's Avatar
shortride
Miles to "E" is based on your average fuel mileage. The only way to get an acurate reading is to check it at the end of a full tank of fuel.
Old Jul 27, 2012 | 08:59 AM
MCDavis's Avatar
MCDavis
From what I recall Miles to Empty is calculated on a historical basis over a series of your last few fillups. I think it takes the mileage averages from the previous 5 tanks, or something in that area, and estimates from there. I wouldn't RELY on the MtoE personally.
Old Jul 27, 2012 | 10:37 AM
FORD OR DIE
so it basically it is useless info. Good thing my wife dosent drive it much cause she would go until it said 0. she likes to run from 1/2 to empty. drives me nuts! she says it to expensive to fill it. I'm trying to get her to fill it when it gets to half and run on the upper half of tank and not the lower half of tank. I dont see that happening anytime soon!! LOL!
Old Jul 27, 2012 | 11:23 AM
Ford8502's Avatar
Ford8502
It is useful when driving on long trips, trying to time your fill ups with the exits on a highway. It's not intended to use for trying to get the last drop out of a tank when running short trips daily.
Old Jul 27, 2012 | 12:53 PM
jacknbella's Avatar
jacknbella
I just filled up over lunch and it said 41 miles til empty but I was able to pump in 25.25 gallons (26 gal tank) so I'm pretty sure I would not have made it very far had I not stopped. Guess I need to pay more attention to the fuel guage from now on!
Old Jul 27, 2012 | 01:42 PM
LSchicago2's Avatar
LSchicago2
Mine have always been good, with 1-2 gallons left when it hits zero miles to empty. You can USUALLY go below empty.
Old Jul 27, 2012 | 06:05 PM
user 708242442's Avatar
user 708242442
It is based on your current mpg reading.
Old Jul 27, 2012 | 06:36 PM
QwkTrip's Avatar
QwkTrip
Mine is over optimistic. And the predictions totally break down with about 100 miles left on the meter.
Old Jul 28, 2012 | 08:19 AM
Ford8502's Avatar
Ford8502
From the owners manual:
MILES (km) TO E
This displays an estimate of approximately how far you can drive with
the fuel remaining in your tank under normal driving conditions.
Remember to turn the ignition off when refueling to allow this feature to
correctly detect the added fuel.
Distance to empty is calculated using a running average fuel economy,
which is based on your recent driving history of 500 miles (800 km).
This value is not the same as the average fuel economy display. The
running average fuel economy is re-initialized to a factory default value if
the battery is disconnected.
Old Jul 28, 2012 | 11:22 AM
BIGKEN's Avatar
BIGKEN
Ford does not want you running out of gas...there is a fudge factor built in. Empty is only empty when your vehicle shuts off and won't go anymore!!!
Old Jul 28, 2012 | 12:15 PM
NASSTY's Avatar
NASSTY
I read on another forum that somebody drove 25 miles after the screen said 0 miles to E.
Old Jul 28, 2012 | 01:49 PM
stephen.osborne1's Avatar
stephen.osborne1
You should never go below about 1/4 tank to begin with... It will cause your fuel pump to cavitate (suck in air) and shorten its life span drastically. Anyone else always keep it on the Miles to empty selection after a fill up? I notice right away how bad some gas is (or good for that matter) when the miles to empty begins to drop or increase after a fill up. It almost always drops when switching from say Chevron to Safeway gas. I've had it drop as much as 80 miles per tank!
Old Jul 28, 2012 | 04:51 PM
flixden's Avatar
flixden
You would not see an instant change from different gas if it uses the last 500 miles for the calculation as the manual suggest.
I can definitely say that the reading is completely messed up once towing a trailer gets into the equation - the system does not know how to differentiate, even if you always correctly switch the setting forth & back between "normal" and "towing" history used.
As long as you did not tow for the last 500 miles, it's a decent "guideline" or estimate of how many miles you got to work with. It seems to always err on the conservative side - as it should - there is some gas left when it says zero.
I don't think there is any problem running the tank to below 1/4 mile. I always do it, have always done it, and have never had a problem with a fuel pump. I believe it's another myth. If there was truth to it, the manual would state that, but I have not seen it mentioned in there.
Old Jul 28, 2012 | 05:07 PM
user 708242442
MILES (km) TO E
My truck was low on fuel today, it changed from being parked on a hill to parking back on level groud so the manual is wrong. it seems to be running off of how much fuel it thinks is still in the tank???
