tranny id help
Old Jul 25, 2012 | 08:53 PM
scardina61's Avatar
scardina61
tranny id help
Does anybody know what tranny a U represents on the door sticker of a 95 f150
Old Jul 25, 2012 | 09:02 PM
Newcomer's Avatar
Newcomer
From what I can find it is a 4R70W, but I thought this transmission was in later model trucks......
Old Jul 25, 2012 | 10:28 PM
burnout400m's Avatar
burnout400m
IIRC from another recent thread the 4r70w was introduced in this generation truck, sometime in the '92-96 F150s and then carried over to the '97+. It's an electronically controlled variant of the AOD.
Old Jul 25, 2012 | 11:14 PM
scardina61's Avatar
scardina61
Does any body have any opinions on this tranny, good or bad, known problems? I ask because sometimes it acts like it dosent want to drop into first or passing unless you floor it all the way.like if you are slowing to a stop for a light then the light turns before you stop all the way, i try to get back on it and it just dosent seem to respond.???
Old Jul 26, 2012 | 12:12 AM
burnout400m
The 4R70W isn't a POS but it's not as strong as an E4OD. If it's not kicking down then it's probably something simple. When was the last time the filter was changed? I don't know much about this particular tranny but I think not kicking down would have more to do with what controls the tranny rather than a shot transmission itself.
Old Jul 26, 2012 | 08:13 AM
Conanski's Avatar
Conanski
Yes.. just like the E4OD this gearbox is completely computer controlled so the first step in diagnosing a problem should always be to pull the codes.
Old Jul 26, 2012 | 10:20 AM
Lead Head's Avatar
Lead Head
Also keep in mind that Ford's transmission programming around this era was really dreadful. So if there are no fault codes, and the TPS checks out good - that's just how it's going to be.
Scgoobertn
1997 - 2003 F150
May 15, 2010 10:50 AM
palace55
May 11, 2010 12:49 PM
68shortbedmo
May 19, 2007 10:12 PM
f100guy
Dec 19, 2003 11:02 PM
Boomer95
Sep 17, 2001 09:53 PM
