Installing a cam
Old May 11, 2003 | 05:25 AM
launer696's Avatar
launer696
Question Installing a cam
First off I have a 90 F150 with a 351w with EFI and I want to put a slightly bigger cam in it. Would the cam mess up the computer? If it does what would I need to do to make this cam work in this engine? Any info would be appreciated.
Thanks.
Old May 11, 2003 | 02:01 PM
90f150moneypit's Avatar
90f150moneypit
Installing a cam
As long as you stay conservative with the duration you shouldn't have a problem. Make sure to check the pushrod length after.
Old May 14, 2003 | 11:40 AM
CGreene's Avatar
CGreene
Installing a cam
I installed a 284/488 lunati in my 92 302 EFI. It idles up and down up and down. I have to convert from map to maf and change the computer.
