I just got a new to me 1991 F150 4x4 today (I'm working on that post next.) But the truck came with some extra parts that I am unsure of what they are and what they fit.
3" body lift? They all measure at 3" so that's what I'm guessing.
The red bushings are polu eurathane bushings for something, but not sure what they go to. kind of looks like a combination of leafsprig bushings and TTB pivot point bushings
the first one is body lift bushings,the red ones are nylon body mount bushings.the next one im not sure and the next one is a lift block for leaf springs
Body lift blocks
Red ones on the right look like radius arm bushing
Red ones on left look similar to a vw engine mount lol
Not window motors.... Those are headlight switches
Lift block
Tailgates from 87 to 97 all interchange. 80-86 probably do also.
Here is the instructions that came with my polyeurethane cab mount bushings. Look at each bushing. There should be a number on each. If they match these instructions, just match up the correct numbers and you may be able to use them if need be.
They're kinda small. I can email the instructions too if you want em. Sorry, didnt see you posted the numbers. Just go to energy suspension.com and they may have instructions for them.
Chris
Reason: Extra info
