Help
Old May 10, 2003 | 07:30 PM
tonga3's Avatar
tonga3
Help
I came home tonight pulled in the garage and turned off my lights, problem is only the parking lights turned off, the head lights stay on, the switch on the rearview mirror is off and the only way to get them to turn off is to disconnect the battery, but as soon as I re-connect they turn right back on again. HELP!!
By the way its a '99 explorer EB 5.0
Thanks in advance
Andy
Old May 12, 2003 | 10:10 AM
mrshorty's Avatar
mrshorty
Help
Electrical gremlins can be the most frustrating of all diagnoses. The only advice I can give is to get a wiring diagram and a volt-ohm meter and start checking the wiring. Check the switch and make sure it's working as it should. There may be a relay that is stuck closed. Be sure to check the grounds carefully.
360andy
Jun 24, 2012 06:03 PM
NS_Andy
1983 - 2012 Ranger & B-Series
Mar 16, 2011 07:13 PM
Tookalookaround
May 30, 2010 09:27 AM
andy wick
Jan 11, 2010 10:14 AM
Andy63
Mar 21, 2003 10:59 PM
