Truck died
Old Jul 21, 2012 | 04:10 PM
_Me2_'s Avatar
_Me2_
That sucks. What's your ICP when cranking warm? Do you have a fuel pressure gauge?
Old Jul 21, 2012 | 04:21 PM
tjustice's Avatar
tjustice
ICP when cranking is good well over 500.....Fixing to hunt the codes for my ScanGauge II for the Fuel Pressure
Old Jul 21, 2012 | 04:39 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Uh oh, there isn't a code. You'll need a gauge and a M12x1.5 by 1/8" NPT adapter. No fuel pressure sensor on the 6.0's
Old Jul 21, 2012 | 04:41 PM
tjustice's Avatar
tjustice
Had taken fuel filter cap off and took filter out, left them for 20 mins, just went back to put back together, fuel assembly was empty??????
Old Jul 21, 2012 | 04:48 PM
tjustice's Avatar
tjustice
Just thought of something else....Didn't think much of till just now: Took plug out of fuel pump to drain and it never really quit running out. Slowed to a small drip, but didnt quit like when usually does when changing filters..... Just a thought, may not mean a thing.
Old Jul 21, 2012 | 04:54 PM
tjustice's Avatar
tjustice
Truck had been sitting for just over an hour,,,turned key started right up...don't know on this issue.....
Old Jul 21, 2012 | 05:03 PM
Rusty Axlerod
I dont want to steer you wrong but I would want to know what the fuel pressure is. did you think to look at FICM v when it was messing up?
Old Jul 21, 2012 | 05:05 PM
_Me2_'s Avatar
_Me2_
Same here. Fuel pressure seems like a long shot, but that's all I can think of at this point so long as the FICM is good, the HPO is good, and there are no injector leaks.
Old Jul 21, 2012 | 05:07 PM
tjustice's Avatar
tjustice
FICM was 49 to 48.5....Made a point to look at it, this is the second one on the truck.... Where do I need to hook the gauge up at?
Old Jul 21, 2012 | 05:10 PM
Rusty Axlerod
DISREGARD the instructions in blue. Don't have anything to do with testing fuel pressure. IIRC the test port plug is a 6mm allen cap screw.
berick's Avatar
berick
Was the FICM reading okay when the truck began acting up? When mine went I never messed around with checking fuel pressure etc... it was under warranty, so I called Ford Roadside Assistance and they came and towed it to the shop. Your issue might be fuel related though by the sounds of it.
Old Jul 21, 2012 | 05:16 PM
tjustice's Avatar
tjustice
FICM was good, ICP was good, IPR was good, EOT was 209 the first time it happened.. 2nd time, was same except EOT was 190....its like it starving for fuel, then runs out... Didnt happen where i could jerk filter cap off real quick to see if had fuel or not, was trying not to get ran over.....
Old Jul 21, 2012 | 05:19 PM
  #28
tjustice's Avatar
tjustice
Just did Blue spring during the HG, a new head, and few other high dollar items....only thing i didnt replace last week was the FICM and the Fuel pump.....FICM is a year old, not that it matters....
Old Jul 21, 2012 | 05:24 PM
  #29
zhilton's Avatar
zhilton
I'm a little late to this discussion, but I'm going to echo what Benny (Blade35) said. I think your getting air in the fuel system at the primary filter/HFCM. As much as I hate to say it...might be worth your sanity to pull the filter, replace the o-ring, cover with a generous amount of clean lube oil and reinstall. That would explain the air bubbles in the secondary filter housing. The other thought would be cracked cap, but I'm thinking you'd have fuel leaking/seepage on the cap if it was cracked.
The draining of fuel from the secondary housing could be the fuel slowly going back to the HFCM via the return line. With the cap off there's no "vacuum" to keep the fuel in the secondary housing. I don't think there's a "drain plug" in the secondary filter housing like the oil filter has.
How did you confirm the injectors are good/not allowing air into the fuel system?
Old Jul 21, 2012 | 05:28 PM
  #30
tjustice's Avatar
tjustice
Combustion Test....no bubbles....
May do the balloon test when get back from getting Fuel Pressure Gauge
The original bubbles were small like forced air bubbles if that makes sense....
