2nd 3g alt?
Old Jul 21, 2012 | 09:46 AM
ford4ever_2003's Avatar
ford4ever_2003
2nd 3g alt?
i was debating on adding a second 3g on my 77 f150 4x4 400. has anyone added one and do i just wire it in the same as the first. i know the mounts for itll have to be custom but that part isnt a problem
Old Jul 21, 2012 | 10:19 AM
fmc400's Avatar
fmc400
MSEE
The question is, why? A single 3G is enough for most practical uses, all that's going to happen is both internal regulators will cut each alternator's output into half of the one you have now. It's not like you'll "pump more juice." The alternator output self-adjusts to maintain a specific voltage across the battery terminals which is what your single alternator is already doing. You won't see any change at all, unless you're having issues, which would mean something is wrong with your existing system. In other words you are wasting your time.
Old Jul 21, 2012 | 10:45 AM
HIO Silver's Avatar
HIO Silver
2X with fmc400.
Troubleshoot your existing system and then consider an auxiliary battery.
Old Jul 22, 2012 | 08:35 PM
ford4ever_2003
i have a big stereo in the truck and lights outside. im just trying to keep the voltage up a little higher. when i turn the stereo up it will go from 13.8 volts down to 11.7 and i already have a second battery
Old Jul 22, 2012 | 09:00 PM
Blue and White's Avatar
Blue and White
Are you sure its an alternator problem and not wiring? Suggest you check and report voltage with the heavy loads applied at the alternator output stud, solenoid and the point of heavy load where you are seeing the low voltage - with the engine reved up a little. More than about .5 volt difference means you need heavier wire or cleaner/tighter connections between the alternator, battery and load.
Old Jul 22, 2012 | 09:08 PM
gpence's Avatar
gpence
You should be running a 0 Gage supply wires between the amp & batteries if you pushing anything big amp wise & deep cycle batteries
Old Jul 22, 2012 | 09:40 PM
Blue and White
... and at least 6 guage from the alternator to battery or starter relay.
Old Jul 22, 2012 | 10:30 PM
fmc400's Avatar
fmc400
MSEE
This means you have a problem with your current system; your focus needs to turn to fixing what you have.
Old Aug 25, 2012 | 09:07 PM
husker77's Avatar
husker77
I know this is a month old but did you get it figured out? If not how big of amp/s are you running? Are the gains set right? If you are clipping your amp you will pull a lot of current.
Old Aug 28, 2012 | 10:54 AM
phathom's Avatar
phathom
Yes you can hookup multiple alternators. No it will not double your voltage. Yes it will help put less strain on each alternator, so they will keep you at a higher voltage (14vdc) on a load.
Coming from a car audio competitor background. I have seen as many as 18 alternators on one vehicle (Alma Gates' Bronco) to support all the electronics.
An easier option, and that would be less hassle, and look cleaner, is to take in your alternator to be rebuilt. Some electrical shops will rebuild them for car audio, to put out more amps to run more equipment. This is done for certain classes that say you have to have only one alternator. It costs a few hundred bucks, but is less hassle, and less issues to possibly deal with down the line.
NotEnoughTrucks2014
Apr 4, 2017 06:48 PM
Greywolf
Electrical Systems/Wiring
Sep 27, 2009 07:49 PM
FordTruckFreeek
Oct 7, 2006 10:33 AM
magic-dot
May 2, 2003 08:51 PM
heffa
Apr 25, 2002 05:58 PM
