Sponsored by: Kumho
sway bar
Old May 10, 2003 | 06:26 PM
SPRINT 12's Avatar
SPRINT 12
sway bar
I have E150 with a 6" lift on it.The rear has a 4" block and add a leaf. It tends to body roll a little in the corners and on real windy days. Will a sway bar in the rear help this , the offroad shop I talked to said I needed a new set of stiffer spring packs. I was wondering what you guy's think.
Old May 10, 2003 | 06:36 PM
StrangeRanger's Avatar
StrangeRanger
sway bar
Do you already have a front bar? If not, adding a rear bar only may make the truck very unstable. It's going to want to swap ends on you. A pair of bars may help, but you probably need to stiffen your rear springs to match the front.
Old May 10, 2003 | 10:20 PM
MustangGT221's Avatar
MustangGT221
sway bar
I think with an add-a-leaf your spring pack will be stiff enough. If you don't have any sway bars at all, you can go to a junkyard and get stock ones, then get the drop links from a lift company (skyjacker sells them) for a 6" lift and bolt it on. You could also get the stock parts to bolt on a sway bar, buy an aftermarket sway bar (better/stiffer), and bolt it on with the drop links from a lift company. My truck doesn't have any sway bars on it.
Kpt3
6.7L Power Stroke Diesel
Oct 18, 2014 08:58 PM
Wilmax
Feb 4, 2013 09:28 PM
pin8246
Oct 11, 2012 10:31 PM
TheHouse
Mar 31, 2009 09:37 PM
bucky95
1978 - 1996 Big Bronco
May 20, 2005 09:33 PM
