1978 - 1996 Big Bronco
What Did I Just Break?
Old May 10, 2003 | 05:24 PM
Brizzadd's Avatar
Brizzadd
Hello all! I have a 96 EB Bronco, I was installing new sway bar bushings on the back today when I broke this thing. It sits right on top of the rear differential, in the way of the sway bar really. I took the bar off and popped the damned thing off. It has a covered wire going to it with two little shiny silver things inside with some thin copper wiring that appears to broken as well. I cranked up the truck to see if anything acted any different and I noticed the ABS light does not go off. What is this thing called, I know it's something to do with ABS but what should I ask for when I go to get a replacement? And is it okay to drive with it being broken?
Old May 10, 2003 | 06:10 PM
mrwizard's Avatar
mrwizard
This thing?
It's the rear ABS sensor.
Old May 10, 2003 | 06:19 PM
Brizzadd's Avatar
Brizzadd
THAT'S IT!!!! THANK YOU!!!!
Old May 10, 2003 | 10:09 PM
bigric's Avatar
bigric
Also called Vehicle Speed Sensor (VSS); should cost about $12 from the Ford dealer.
Old May 10, 2003 | 11:19 PM
steve83's Avatar
steve83
Next time, check here.
