Tranny Fluid Change
Old May 10, 2003 | 05:10 PM
MisterCMK's Avatar
MisterCMK
Talking Tranny Fluid Change
I just changed the fluid on my 2000 EB at 368xx miles. Ford sure did make this an easy procedure. The torque convertor had a drain plug on it which made the job easy. Also, the pan had a drain plug. I didn't have to balance a pan full of transmission fluid. I must give ford the credit the deserve on this one.
-CHRIS
Old May 10, 2003 | 10:30 PM
buzzard's Avatar
buzzard
Tranny Fluid Change
Ditto on the tranny fluid change, especially with the drain in the pan. Too bad nearly everything else is a bi#ch to work on though.
Old May 11, 2003 | 12:49 AM
BigMattXXL's Avatar
BigMattXXL
Thumbs up Tranny Fluid Change
Yeah, it's definitely a fairly smooth operation.
I heard that Ford charges some ungodly amount of money to perform a transmission flush.
XXL
Old May 28, 2003 | 05:47 PM
PEPpfts's Avatar
PEPpfts
Question Tranny Fluid Change
Hi,
I want to do a tranny fluid change on my 1998 Expedition.
Do you know if the is there a torque convertor drain plug on this model ?
How would I access it ??
Thanks
Lou
Old May 28, 2003 | 05:59 PM
MisterCMK's Avatar
MisterCMK
Tranny Fluid Change
Originally posted by PEPpfts
Hi,
There should be a drain plug. You need to turn the engine over by hand until the plug appears. There is a little black plastic/rubber plug that covers the hole for the TC.
-CHRIS
Old May 28, 2003 | 06:16 PM
PEPpfts's Avatar
PEPpfts
Tranny Fluid Change
Thanks for your reply Chris.
I saw the rubber grommet that covers the hole.
Exactly how do I turn the engine over by hand ???
Thanks again.
Lou
Old May 28, 2003 | 09:17 PM
buzzard's Avatar
buzzard
Tranny Fluid Change
You can put a socket on the crank bolt and turn with a breaker bar or you can remove the fuel pump fuse and have a helper crank the motor over until the plug happens to stop at the 6 o'clock position.
Old May 28, 2003 | 09:47 PM
MisterCMK's Avatar
MisterCMK
Tranny Fluid Change
Putting the socket on the crank bolt is easiest. That way you don't have to mess with priming the fuel system. It is pretty easy. It helps to have 2 people. One to turn over the engine, and one to look for the TC drain plug.
-CHRIS
Old Jul 9, 2003 | 04:48 PM
PEPpfts's Avatar
PEPpfts
Tranny Fluid Change
Hello Everyone !!
I/m finally getting around to changing my Tranny Fluid soon.
Can anyone fill me in on whether I need a new pan Gasket for the tranny pan ?? When I looked at the pan it was stamped with "reusuable gasket " . Is this the case ?
Also does this Tranny take a new filter ?? or do you just clean the same one ?? If so, what is the proccedure ??
Thanks in advance !!
Lou
Old Jul 9, 2003 | 05:04 PM
PbFoot's Avatar
PbFoot
Tranny Fluid Change
Take a look at the gasket after you drop the pan. If it is in good shape you can reuse it. I'm pretty sure the filter is replaced with a new one.
Pbfoot
Old Jul 9, 2003 | 05:54 PM
MisterCMK's Avatar
MisterCMK
Tranny Fluid Change
I was able to re-use the gasket from my pan. It looked like it was in good shape. The new filter also came with a gasket. The filter is, and should be replaced. That way it is keeping your tranny fluid clean instead of filtering it through dirt and crud.
Old Jul 11, 2003 | 08:24 PM
RDavis - OKlahoma's Avatar
RDavis - OKlahoma
I'm a novice mechanic a best so please don't let this question insult anybody's intelligence. How do you re-fill the TC with transmission fluid after it has been drained? Does the TC fill at the same time the pan is filling through the engine compartment transmission fluid fill port / check?
Robert
Old Jul 11, 2003 | 08:52 PM
MisterCMK's Avatar
MisterCMK
Tranny Fluid Change
Check this out. https://www.ford-trucks.com/articles...hangingatf.php I followed the steps here, and it worked just fine. It has you start the truck for 30 seconds, then turn it off. Just follow this guide, and it will work just fine.
Old Jul 11, 2003 | 08:59 PM
RDavis - OKlahoma
Tranny Fluid Change
Thanks mistercmk - Exactly what I needed.
Old Jul 13, 2003 | 05:49 AM
user 8429720834's Avatar
user 8429720834
Banned
Tranny Fluid Change
The procedure posted states to not use Dextron V in the 4r100! Last month the dealership change the tranny fluid in my 2000 exp to Dextron V. The dealership claims they change all 4r100 to Dextron V when flushing the tranny. The owners manual also says to use Dextron. So what gives? Should I have the Dextron V fluid changed again to Dextron?
