17+ Volts?
Old Jul 19, 2012 | 02:21 PM
skyfox10's Avatar
skyfox10
Question 17+ Volts?
Ok, trucks been running good (for the most part) lately. As much of the country, we've been in drought over the last couple months. We finally had our first good rain last night, and it was good enough that I lost electricity at home and it hadn't come on yet when I went to work.
Anyways... Started the truck and turned on the headlights, headlights did not come one, alternator light was on, and voltage gauge was all the way up. It seems that my parking lights work, but the headlights do not.
I got out a multimeter put it to the terminals, showed over 12v. started the truck and it went up over 17. Now I'm thinking that my headlights might now be working because they had to much power going to them, possibly ruining them, the switch, or blowing a fuse.
Is this a simple voltage regulator problem?
Old Jul 19, 2012 | 02:35 PM
Evan_P's Avatar
Evan_P
Sounds like a bag voltage regulator.
Old Jul 19, 2012 | 03:32 PM
AkF250HD's Avatar
AkF250HD
Sounds like a bad vr and it probably blew the headlight fuse. I'd check the truck over real good and make sure everything else is working.
Old Jul 19, 2012 | 03:36 PM
skyfox10's Avatar
skyfox10
I may have an spare alternator from my old truck somewhere... I'll have to do some digging... Is the regulator on the alternator or somewhere else? I hope it didn't screw up any other components... Will keep you posted.
Old Jul 19, 2012 | 05:02 PM
AkF250HD's Avatar
AkF250HD
Most of the newer vehicles have the vr built inside the alternator. Can you share more details on your truck, motor and such.
Old Jul 19, 2012 | 05:58 PM
Conanski's Avatar
Conanski
Regulator is attached to the back of the Alt and it's relatively easy to change.. only special tool needed is a paperclip to hold the brushes back while the body is bolted in place.
Old Jul 21, 2012 | 08:43 AM
skyfox10's Avatar
skyfox10
96 F150. 351, 4x4, Single Cab, Short Bed.
Sorry for the delay in getting back here. I've had a busy couple days the I left the truck parked. I got home the night after this all occurred and found the alternator was warm to the touch. So i disconnected the alt and found the truck didn't start as well as it normally does, so I suspect that current was backfeeding into the alt somehow.
I got home after dark last night, found the alternator from my old truck, removed the alternator from my current truck, and swapped regulators. It now is reading the correct voltage.
Also, all my fuses are OK. I have hi-beams but not low. So I'm hoping when I pull a headlight today I find that the element is just shot, because I'm guessing that only leaves the headlamp switch as the remaining possible victim. (Guess I shouldn't have procrastinated on getting a relay setup for so long)
Is it normal for the alternator to warm up when a regulator goes bad?
rat49f6
36
Jun 5, 2018 09:58 PM
76f350spercamprspeal
Feb 9, 2013 09:04 PM
bodabdan
Sep 25, 2011 06:01 AM
78sharpshooter
Jun 19, 2007 01:01 PM
volfan945
Electrical Systems/Wiring
Aug 24, 2004 03:19 PM
