??? Front wheels leaning out...
Old May 10, 2003 | 09:18 AM
Rick X's Avatar
Rick X
Hi all,
'78 F100 2WD 400 C6...
When looking at my truck from a distance as it goes down the road it appears that my front wheels are leaning out, i.e. top of tire in towards truck and bottom of tire out away from truck. I'm not very good at suspension problems...so, any insight or help would be appreciated...
Thanks,
Rick
Old May 10, 2003 | 09:22 AM
Rat A Tat's Avatar
Rat A Tat
Sounds like saggy springs
Also look at your bushings.
Old May 10, 2003 | 12:22 PM
73Custom's Avatar
73Custom
I agree, your springs are weak and the front end is sagging. Because of the way the twin I beam front ends are made, a sagging spring will throw the alignment all off.
Get new springs, and it would be a good time to replace the radius arm bushings and axle pivot bushings with polyurethane replacements.
Marty
Old May 10, 2003 | 12:55 PM
Crowbar65's Avatar
Crowbar65
Could be springs, but I would also look at the king pins.
When they go bad it can get a little sloppy under there.
Old May 10, 2003 | 04:16 PM
Torque1st's Avatar
Torque1st
Posting Legend
Actually, for proper terminology your tires are leaning IN... Or have excess negative Camber. Your tires should probably have a little negative camber in order to steer properly. Check the alignment specifications.
Old May 23, 2003 | 03:03 AM
neverenough's Avatar
neverenough
A 400 BB in a 100? What was the original motor? It sounds like the springs are overloaded. How does the truck ride in the front? A little soft? You may need to swap in some heavier duty springs. Maybe 250 springs or springs from a 75/6 150 with a 360 might work. You could also go to a spring and suspention shop and see what they might have to correct the problem. You can bend the I-beams only so far to align it.
rickvm
Electrical Systems/Wiring
18
Aug 28, 2014 05:00 PM
Dave2488
Aug 1, 2012 12:54 AM
Rick92
Michigan Chapter
18
Feb 5, 2012 10:29 PM
Rick_Ford
Jan 12, 2004 06:19 PM
rick
Sep 26, 2001 06:18 AM
