Brake fluid
Old Jul 17, 2012 | 05:05 PM
reospw's Avatar
reospw
Brake fluid
Hi all.
Had my brakes done at the FORD DEALER. Had a pulsing when I applied the brakes. All new pads and rear rotors installed. No pulsing now, but it did not stop correctly. Brought it back, they say nothings wrong. I know how it's supposed to stop.
Followed recommendations posted here last week. Checked the rubber lines. No cracking, swelling or leaking. Bled the brake calipers, no air, However the fluid was jet black. Did three rounds of bleeding in the correct order, used 5 cans of DOT 3 fluid, now it's light brown.... STOPS a lot better.
Should the fluid be clear at the calipers?
Should the Ford Dealer have checked this?
Thanks again.
Old Jul 17, 2012 | 05:52 PM
goodmatt2002's Avatar
goodmatt2002
The fluid should be clear at the calipers. If you didnt specify for them to flush the brake system then they would have no reason to do so. Changing rotors and pads does not require any change in the fluid other than the fluid level will rise in the reservoir.
Old Jul 17, 2012 | 05:54 PM
goodmatt2002
Also flush the power steering fluid as it will improve the pressure on the power assist and the brakes will feel better. I just did mine and it helped alot.
Old Jul 18, 2012 | 01:32 AM
Monsta's Avatar
Monsta
Sit. Stay.
Provided it's a diesel.
Old Jul 18, 2012 | 09:36 AM
az_r2d1's Avatar
az_r2d1
I always open the bleeder when pushing the pistons back. Prevents the crappy fluid at the caliper from flowing back into the lines.
I usually bleed the brakes right after it. Might as well while while you are at it.
I agree, unless you told them they won't bleed the brakes.
to op:
Still doesn't explain why it didn't brake right.
What exactly did it not do right ?
Old Jul 19, 2012 | 10:27 PM
goodmatt2002
Good catch!
tufdog71
15
Nov 17, 2019 07:23 PM
ReddTruck
2004 - 2008 F150
May 6, 2019 11:50 AM
SD Rick
Jul 4, 2011 09:12 PM
Keepin It Real
Mar 25, 2007 08:24 PM
bdclark
1978 - 1996 Big Bronco
Aug 12, 2003 10:11 PM
