trans swap
Old Aug 6, 2002 | 05:36 AM
keithi70's Avatar
keithi70
trans swap
Old Sep 23, 2002 | 12:07 PM
HomeGrown's Avatar
HomeGrown
Post trans swap
Hey I was wondering what would be another good 5 speed to swap for my m5od in a 95 f150 300 I6.
Old Sep 23, 2002 | 03:09 PM
gamehunter's Avatar
gamehunter
trans swap
If you want to stick Ford the next strongest up from the M5OD is the ZF if you want OD and if you dont care your choices are more numerous. The ZF comes in two variations but is basically the same thing. I think one is a little more revised. They both bolt up the same way however and should work nicely with your 4.9L. This trans is a little shorter I believe so it would require lengthening of your rear shaft and shortening of your front if you have 4x4. 4 speed choices are and not limited to: NP 435, T-18, and basically any other ford trans with a 90 degree bellhousing. Why are you changing tranny?
Old Sep 24, 2002 | 07:40 AM
HomeGrown's Avatar
HomeGrown
trans swap
I'm not sure that I want to change it. I was just looking for a stronger one. Just more curious than anything.
Old Sep 24, 2002 | 07:52 PM
gamehunter's Avatar
gamehunter
trans swap
If you plan on keeping your inline 6 dont bother. Your engine will never make enough HP to burdon the M5OD. Someone in an earlier post said they were running a stroked 351 behind it without any trouble. Only do the swap if you can't live with your gear ratios.
Old Sep 25, 2002 | 06:58 AM
HomeGrown's Avatar
HomeGrown
trans swap
thnaks for the info
