transmission selector cable
Old Jul 16, 2012 | 02:31 AM
jeffu86's Avatar
jeffu86
Question transmission selector cable
Hi all, I'm new to the group and I just bought an 84 f250 with a 6.9L in it. I haven't been able to take the steering column apart yet (I wont have the truck til later this week) but the transmission selector cable either needs adjustment or be replaced. Does anyone know where I can buy a new cable for this truck online? Thanks!
Old Jul 16, 2012 | 09:01 AM
klricks's Avatar
klricks
I don't know where to buy on but my selector cable is bad as well. It is a very small diameter wire or maybe even string in a plastic sheath functions like a bicycle cable. The sheath gets brittle and breaks into pieces so the cable does not work well. Too much slack which makes the pointer off. At least that is what happened to my truck.
Old Jul 16, 2012 | 11:11 AM
smashclash's Avatar
smashclash
on my truck it's a thin wire. I believe it might be copper too. I would try a junkyard.
Old Jul 17, 2012 | 03:40 PM
jeffu86's Avatar
jeffu86
alright thank you both for the info.
Old Jul 18, 2012 | 08:10 AM
douglpr42's Avatar
douglpr42
lmc truck has them
Old Jul 18, 2012 | 11:45 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
FoMoCo sold the shift indicator dial & cable as a one piece assembly. The cable is not available by itself.
For those of you (ctubutis, Gary Lewis, et al) with the 1980/89 Ford Light Truck Parts Catalog, look here: Illustration Section 106 ~ Page 3.
EOTZ-7A110-B .. Shift Indicator Dial / Available from Ford.
MSRP: $77.83 // FTE Ford Dealer Parts Dept sponsor horizonpartsguy.com price: $56.04 / Horizon Ford Truck Center in Seattle (Tukwila) WA
Applications: 1980/86 F100/350 & Bronco all A/T except AOD.
E1TZ-7A110-A .. Shift Indicator Dial / Obsolete
Applications: 1981/82 F100/150 & Bronco with AOD only / No Ford Dealer or obsolete parts vendor has any.
E3TZ-7A110-A .. Shift Indicator Dial / Obsolete
Applications: 1983/86 F100/150 & Bronco with AOD only.
KINSEL L/M in Beaumont TX has 1 = 800-816-2894.
PARTS INTERNATIONAL in Farmers Branch TX has 1 = 888-727-0418.
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
FORD PARTS ONLY in Bayamon Puerto Rico has 1 = 787-786-9180.
No other Ford Dealer or obsolete parts vendor has any.
Old Jul 18, 2012 | 10:37 PM
ctubutis's Avatar
ctubutis
Thank you, Bill.
One thing I have noticed... I called a Ford dealer the locater thinger told me had a fuel line for my Tempo. The guy said: "The computer says we have it but I can't find it, it's probably on a pallet with a bunch of other old stuff in the back of the storeroom."
Point being, just because the computer says they have it, don't hold your breath....
Old Jul 19, 2012 | 02:40 AM
jeffu86's Avatar
jeffu86
Thank you everyone for the info. If or when I need to change it out I will definitely check out those sources.
Old Jul 20, 2012 | 06:21 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
The cable is replaceable if you can find a good one somewhere, as it's bolted on at the indicator end. Some people have also made their own. I'd search the forum for all avaliable options.
Only source for a replacement cable would be a wrecking yard, because as Bill said, they were not sold seperately.
Old Jul 20, 2012 | 06:31 PM
81-F-150-Explorer
duplicate post...
Old Jul 20, 2012 | 07:52 PM
jeffu86's Avatar
jeffu86
Yeah I was recently told about a junk yard we have here locally that I'm definitely going to check out if its more than just an adjustment
Old Jul 20, 2012 | 10:30 PM
NumberDummy
See post 6. The shift indIcator dial comes with the cable. The 1980/86 non AOD indicator dial assy is available from Ford. Both the 1981/82 AOD & 1983/86 AOD dials are obsolete.
No one has the 1981/82 type, but there are 4 of the 1983/86 type available NOS
I have to wonder why anyone would go to a wrecking yard, strip the dash apart to get at the puppy. And, once it's found, will it be any good?
If not, move on to the next one. If you don't succeed the first time, try - try - try - try - try again.
OP lives in the high desert city of Lancaster. It was 96 degrees in Hacienda Slights today, I can just imagine how hot it is in Lancaster.
I was gonna whiz up to Acton tomorrow (Saturday), but Acton is close to Lancaster. So, it's too damn hot to visit Daphneyland to adopt another Basset Hound.
Old Jul 21, 2012 | 12:20 AM
jeffu86's Avatar
jeffu86
It has been hot here. We had a few cooler days when the clouds passed over from the storms north of here which was a nice little break.
Old Jul 21, 2012 | 01:51 PM
81-F-150-Explorer
Just listing avaliable options.
The new shift indicator dial does come with the cable yes, but you can unbolt that cable from the indicator. If you do have an AOD, you could find any type indicator in the wrecking yard and just swap the cables for example.
Finding one that's good might be a trick though, but still an option.
Old Jul 22, 2012 | 11:16 PM
jeffu86's Avatar
jeffu86
Well I got my truck today and took a look at the indicator cable. The cable is in good shape. The issue is with the tubing that the cable is inside of. It looks like over the years the tubing has cracked and fallen apart which has effected the proper cable tension.
So I'm with you, klricks. I figure I could come up with a new tubing and cut to the size it needs to be for the proper tension.
Thanks again to everyone for the advice and comments.
