my buds truck
my buds truck
my bud just put a 460 in his 79 so he can be like me lol and he has a rebuilt edelbrock that whistles i assume this is just a slightly leaking diaphragm what do you fellas think? i know when the 460 had a Holley on it it didn't but as soon as he put edelbrock on it it made better power but has a loud screaming whistle thats annoying as hell
That's a vacuum leak. Make sure the two small ports on the front are capped if they're not in use; and make sure the port in the back has a pipe plug installed if it's not in use. Make sure the carburetor is bolted down properly and evenly with a proper gasket in between.
The accelerator pump diaphragm is not exposed to vacuum and has nothing to do with the problem.
You'll have to look for vacuum leaks by leaning out the idle mixture so that the truck barely runs, then spraying around suspect areas with a can of carburetor cleaner and listening for a jump in idle speed. If everything were plugged and bolted down correctly, you wouldn't have this problem - therefore you'll need to find it with this test.
well i have a holley 2bbl on top of an adapter plate going to my 4bbl intake, what kind of gasket should i buy to put under the adapter? i need to get rid of this noise
if you have a 4bbl to 2bbl adapter you use a 4bbl gasket underneath and a 2bbl gasket between top and the underside of the carb.... i like using a 4bbl intake with a 2bbl carb i always seem to get better gas mileage with that set up...... if worst comes to worst i guess you could probably use rtv silicone i personally don't use it unless i have to
