68 ranger engine swap
Old Jul 11, 2012 | 10:55 PM
weldworks54's Avatar
weldworks54
I'm thinking about swapping my original 240 out for a 351W what are yalls thought on ditching a matching numbers motor for the winsor? Also have a couple questions about fit meant to my transmission I have a 3 on the tree and really don't want to mess with removing the clutch pedal and all that stuff right now will my bellhouseing , cluth assembly, and transmission bolt up to the winsor? Or should I be looking for a c4 or c6 trans and go ahead and swap out the colum for an automatic colum?
Old Jul 11, 2012 | 11:14 PM
finneys98xj's Avatar
finneys98xj
There ain't any matching numbers as far as motors/Ford trucks. With that said your truck do what you want.
Old Jul 12, 2012 | 05:06 AM
jowilker's Avatar
jowilker
The W should bolt up to the bell. You will need 302 engine perches from I believe 68-79. The swap shouldn't be very complicated using items for 302.
You are not going to hurt the value of the truck. IMHO
John
Old Jul 12, 2012 | 05:36 AM
f5fordgirl's Avatar
f5fordgirl
The only other part other than mentioned, is a V8 flywheel, the 300 will fit and work, but will shake your truck apart.
Old Jul 12, 2012 | 10:59 AM
RichS2659's Avatar
RichS2659
John
You can also use the perches/towers for 77-79 351M/400 trucks as per ND.
Old Jul 12, 2012 | 03:19 PM
weldworks54
John
Thanks for your input I don't want to destroy the value of the truck swapping engines out just to say I have a winsor in it
Old Jul 12, 2012 | 05:19 PM
jowilker's Avatar
jowilker
Correctomondo! I left it out kinda as information overload. Sometimes you put in too much info and it can confuse. Stay simple.
John
woodruf
Feb 6, 2016 06:41 PM
aj1
Feb 17, 2011 11:00 PM
wadlum22
17
Mar 11, 2008 11:02 PM
Karm
Engine Swaps
Oct 6, 2007 09:11 PM
Sycostang67
Engine Swaps
Oct 26, 2004 08:55 AM
