1972 f100 explorer color code 3M?
Old Jul 11, 2012 | 10:16 PM
Scooba's Avatar
Scooba
I am then proud new owner of a 1972 f100 explorer. I successfully decoded most of the warranty tag but the color code is bugging me. It says "3M".
I'm confused because the truck is currently painted what I would call Swiss aqua, and 3=Swiss aqua. What is that m doing there?
Vin f10glp51013
Wb 115
Color 3M
Model f100
Body 4 4
Trans G
Axle 1 7
04450
134
3600
Dso 23
Thanks!
Old Jul 11, 2012 | 10:56 PM
HIO Silver's Avatar
HIO Silver
Welcome to FTE.
In some past life your rig was apparently two-tone... M is Wimbledon White. The pattern could have been regular, deluxe, or combination as illustrated below:
Source: Decoding Your 1972 Ford Truck VIN - FORDification.com
Old Jul 12, 2012 | 04:33 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I'm confused because the truck is currently painted what I would call 3=Swiss aqua. What is that M doing there?
Two COLOR codes: Truck was tu-toned originally.
VIN F10GLP51013 / WB 115 / Color 3M / Model F100 / Body 4 4 / Trans G / Axle 17 / GVW 04450 / Cert. net HP 134 / RPM 3600 / DSO 23
Welcome to FTE
F10 = F100 2WD
G = 302 2V
L = Michigan Truck Assembly Plant.
P51013 = 1972.
115" Wheelbase.
3M: 3 = Medium Bright Aqua / M = Wimbledon White.
F100 2WD, 4,450 lbs. GVWR
4 4: 4 = Black all Vinyl / 4 = Styleside Pickup.
G = C4 Cruise-O-Matic.
17 = Ford 9" Rear Axle / 3.25-1 / no Limited Slip / 3,300 lb. Rear Axke Capacity.
4,400 lbs. Gross Vehicle Weight Rating.
134 net HP @ 3,600 RPM
DSO 23 = Memphis TN Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Jul 12, 2012 | 06:22 AM
Scooba's Avatar
Scooba
Ohhhhh wow. I can't believe I missed that. Thanks!!
IntrstlarOvrdrve
Dec 11, 2014 05:12 PM
CajunChris
18
Jan 15, 2014 07:55 PM
cowmankev
Oct 6, 2013 07:47 AM
Pixleyyy
Aug 13, 2013 09:55 PM
jazzmaffy
Apr 9, 2010 10:50 AM
