tire psi
Old Jul 9, 2012 | 06:50 PM
cory5517's Avatar
cory5517
tire psi
When running about 70mph I get a vibration from the rear tires. I've looked and I'm not missing wheel weights. I'm also running 70 psi in my load rated e tires. what could be my problem? Thanks in advance
Old Jul 9, 2012 | 07:17 PM
F350-6's Avatar
F350-6
Air pressure won't cause it to vibrate. Are you sure it's the rear? Have you checked the shocks? Carrier bearing? Looked for any uneven tire wear to determine which tire it may be?
And just because there are no missing weights doesn't mean the tires don't need to be balanced. Perhaps some stick on wheel weights fell off. Perhaps it's a broken belt in the tire. Perhaps it's a weight that fell off the drive shaft. Could be lots of things that you have to try and narrow down.
Old Jul 9, 2012 | 07:44 PM
cory5517's Avatar
cory5517
I can eliminate shocks, just replaced them. I was coming home from san antonio flying down 281 at 70 mph and my cups in the cupholder starts shaking, my cb radio is shaking and my change in the ash tray is shaking.
Old Jul 9, 2012 | 07:45 PM
cory5517's Avatar
cory5517
I'm not sure of its in the rear just seems like it
Old Jul 9, 2012 | 07:58 PM
F350-6's Avatar
F350-6
I put brand new Monroe shocks on my truck once after some new tires. A few weeks later I developed a howling noise at speed that everyone swore was coming from the rear. Finally noticed one day that every other hump on the front right tire was worn funny. Tire guy said that wear was from a bad shock. Monroe gave me new front shocks for free, but I got to buy another tire.
Just saying, keep an open mind.
Old Jul 9, 2012 | 08:12 PM
cory5517's Avatar
cory5517
I wish I could afford new tires
Old Jul 10, 2012 | 09:09 AM
Brother Les's Avatar
Brother Les
Rotate your tires and see if there is a change in the 'vibration'.
Old Jul 10, 2012 | 09:54 AM
brian42's Avatar
brian42
Veteran: Navy
I would have them rebalanced if this just started cropping up as F350-6 mentioned.
I try to get mine balanced about every 3-5K to get the most out of my BFG Mud-Terrains. I just had them done and the truck would start vibrating around 60mph when I got on the freeway. Took it back and had them re-do all four wheels. Now it's smooth again.
Just my .02
Old Jul 10, 2012 | 10:00 AM
cory5517's Avatar
cory5517
I'm gonna take my truck in and get tires rebalanced and rotated
Scott98065
Mar 26, 2018 05:11 AM
tweetie11
Apr 28, 2011 12:32 AM
montana_highboy
22
May 18, 2009 02:21 PM
Sn0wMan
Offroad & 4x4
Mar 1, 2007 08:50 PM
rkersh409
Jul 19, 2005 09:01 PM
