Having an odd problem with my AC and was hoping someone could help me out. The air conditioner has periods where the fan won't blow in the front. The rear unit seems to work fine. During the intermittent period where the font unit fan is working, the air is cool.
The fuser for the front blower (#107) is fine, not to mention, if it was a fuse issue it probably wouldn't work some days and not others.
I am thiking it's an issue with a loos wire at the fan, or a switch failing, but I'm not too sure about how to approach either issue..
Anyone had a similar issue that can share how they went after it, or have any ideas for me?
When the fan is on does it change speed when you select the different fan levels or does it just run on one speed. On my 01's there is a resistor on the firewall that fails that would cause it to run at only one speed it could be an issue there.
