Windsor Intake Manifold Gaskets
Old Jul 8, 2012 | 10:55 AM
bruno2's Avatar
bruno2
What is the best style of intake manifold gaskets to use on the 351W or 302?I am running an Edelbrock Performer intake so there is no valley pan like the stock cast iron 4bbl manifolds. So I dont need that gasket.
This is the style I used the last go around Mr. Gasket 210 : Mr. Gasket Ford Intake Gasket - 351 Windsor 1969-74.
I didnt have any problems because I used a half gallon of silicone when I installed them. I am just wondering if there is a better option out there?
Old Jul 8, 2012 | 12:44 PM
Franklin2's Avatar
Franklin2
I would use what edelbrock recommends. I have had problems before sealing these aluminum manifolds, the aluminum expands at a different rate than the block and heads, so the sealing surfaces "scoot" a little bit during each warm-up and cool-down cycle.
Make sure you do not use any silcone around the ports where the fuel goes into the head. The fuel will turn the silicone into a goo. The fuel seems to disintegrate the silicone. If you must use some type of sealer around the fuel ports, use the permatex 2 type sealer, it's resistant to fuel.
Old Jul 8, 2012 | 12:53 PM
81ChopTop's Avatar
81ChopTop
Yes, use what Edelbrock recommends. I've heard of people having problems with some of the "lower quality" gaskets with Elel's intakes. I always clean surfaces with lacquer thinner and use Permatex Ultra Blue on the cork front and back strips. Don't forget to dab some where the sides meet the corks.
Old Jul 8, 2012 | 08:12 PM
Stangrcr1's Avatar
Stangrcr1
I don't have an Edelbrock, but I used FelPro intake gaskets on my factory aluminum 2bbl intake.
sweetlou1
Dec 8, 2014 10:45 AM
Falcon Guy
Apr 7, 2009 03:51 PM
asmith6
Nov 30, 2007 09:35 PM
Nev. Bronco
Feb 26, 2005 10:38 PM
76 F250 4X4
Sep 21, 2004 06:50 AM
