Sponsored by: Real Truck
MPG
Old Jul 7, 2012 | 10:33 AM
Ray 2's Avatar
Ray 2
MPG
Hi I am new to this, bare with me. I have a 2011 Ford F250 SD,ext cab, 8ft bed w topper, 6.2 gas V8, 6sp automad, 2wd. I tow a 32ft travel trailer. I have a lot of hp but my MPG suck. I average 7.3 mpg towing.Is there anything I can do to improve my mpg?? Thank for the help. Ray
Old Jul 7, 2012 | 10:48 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
sorry man, you have just discovered the joys of towing a huge trailer with a gas motor
even with a PSD, I think you'd be lucky to get 10 mpg.
to improve mileage, get a trailer that's more aerodynamic. not much else will work unfortunately besides keeping it slow 60-65 mph
Old Jul 7, 2012 | 11:10 AM
biz4two's Avatar
biz4two
Arrow
Welcome to FTE!
Actually...your mpg are not all that bad for your SD configuration. I am also guessing...that you have 3.73 gears...which reduce your mpg's too.
So here are a few tips:
1. proper inflated tires while towing
2. filling up with gas that has less ethanol in it. Ethanol offers more hp...but reduced mpg's
3. reduce speed
4. Using manual mode more to hold gears that are keeping your 6.2L engine in the right rpm's for the conditions. If you play with it...you'll know what I mean.
Good luck...
biz
Old Jul 7, 2012 | 11:14 AM
Ray 2's Avatar
Ray 2
MPG
Thanks Tylus. Can I ask what is a PSD ? If it get me 10mpg that is a lot better then 7.3
Old Jul 7, 2012 | 11:18 AM
kd0axs's Avatar
kd0axs
PSD = Power Stroke Diesel
Unfortunately, as the others stated, that's just the nature of the beast. Biz4two offered a few good tips there that can help, the biggest of which in my opinion would be to reduce your speed. Towing a travel trailer is like pulling a huge sail down the road. The faster you go, the harder it is to pull, and the more fuel you will use. If you are going 70, bring it down to 55-60.
Old Jul 7, 2012 | 12:32 PM
Sand_Man's Avatar
Sand_Man
+1 to all the above. The pros and cons of towing with a gas truck are that they are powerful, reliable, quiet and affordable. They are also thirsty. It's been debated here plenty and everyone sees it differently, but if an extra 3-4 mpg is going to make or break the deal you need a different truck because there is no silver bullet for mpg's with a big truck.
Old Jul 7, 2012 | 12:56 PM
Ridenred333's Avatar
Ridenred333
I noticed just being empty with my v10 that if i dropped speed from 75 to 60 my mpg went from 11 mpg to 14 mpg.
Old Jul 7, 2012 | 01:10 PM
Ray 2's Avatar
Ray 2
MPG
Thanks everyone. I just needed to hear it, but thats what I thought to start with.
Old Jul 7, 2012 | 02:12 PM
Knothole's Avatar
Knothole
Just arbitrarily staying at a slower speed could cost you if you do not speed up going downhill and use some of the momentum to boost you up and over the next one.
Same way with cruise control. It will have you actually braking going downhill and floorboarding climbing the next one.
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Can I ask what your mileage is unloaded?
Old Jul 7, 2012 | 03:10 PM
Ray 2's Avatar
Ray 2
MPG
Ya Tylus, it is about 12.8 mpg the best I can figure.
Old Jul 7, 2012 | 03:29 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Damn. Ouch!
I'd have figured a 2wd to be better. Especially with yours being lighter than mine by about 1500 lbs
Old Jul 7, 2012 | 03:34 PM
mikeismadness's Avatar
mikeismadness
If you pull the camper a lot i would bump up to 4.10s it may help in the mpg a bit
Old Jul 7, 2012 | 09:57 PM
Quad Racer's Avatar
Quad Racer
So you have a 6.2 V8 2wd truck and your complaining about MPG? Good luck with that one. Not to be a jerk, but really.
Also I'm calling B.S. on 14 MPG on a V10 there ridenred333.
Old Jul 7, 2012 | 10:12 PM
Ridenred333
That is my true cal from driving from augusta ga to fort rucker but never going over 65. I do also have the 235/75r16 tires and am not pulling anything. I was really surpirsed by the numbers. If i drive stop and go on post and around town it just under 10.
