Help!!!! 7.3l
Old Jul 6, 2012 | 04:40 PM
Jake_f16's Avatar
Jake_f16
Help!!!! 7.3l
I am pulling with a 7.3l up the mountains in phoenix az and got a check engine getting code p1211 fuel pressure issue. Runs fine it seems like.
Old Jul 6, 2012 | 04:43 PM
BigAlsPSD's Avatar
BigAlsPSD
The P1211, is an ICP too high or too low for a given time, I want to say 4 seconds. Generally if you have a tuner that is commanding a higher pressure and it is not met that is the most common issue. The light will go out after a few minutes. If on a stock truck you might be losing high pressure oil, or could have a rare weak high pressure oil pump.
I wouldn't worry too much just yet.
Old Jul 6, 2012 | 04:54 PM
Jake_f16's Avatar
Jake_f16
Thank you. Oil pressure gage is perfect and towing perfect.
Old Jul 6, 2012 | 04:57 PM
BigAlsPSD's Avatar
BigAlsPSD
Yeah the dash gauge is for the Low Pressure oil side, it fills the reservoir for the High Pressure Oil Pump(HPOP)
Your injectors use High Pressure Oil to intensify and up the injection pressure to thousands of psi. The code point towards the Injector Control Pressure(ICP) not meeting what is being asked of it.
Old Jul 6, 2012 | 11:28 PM
LifeIsGood85383's Avatar
LifeIsGood85383
You guys rock...
Almost better than a genie in a bottle...keep up the great work!
Old Jul 7, 2012 | 12:06 AM
Ponyboychris's Avatar
Ponyboychris
So Jake, are you running a tuner/chip?
Old Jul 7, 2012 | 09:17 AM
Jake_f16's Avatar
Jake_f16
No i am not running a tuner or a chip but do believe the guy before me had one on this truck.
FN74
Mar 14, 2010 11:09 PM
FN74
Mar 14, 2010 02:58 PM
menzfamfour
Jul 7, 2007 03:33 AM
357fhp
Jan 13, 2007 04:32 PM
