Thanks HIO for the reply I meant $45 for everything now back tho the notch the radius arm that it came of stick out pass the I beam mi truck doesn't so that means the bracket has no stability because I have no where to make the notch plus it looks like the opening on the C bracket is to wide to fit in the I beam of my truck it looks to me like I would have to put some flat washers in between the C bracket so that wen I tighten it it wont close up and buckle dose this make sense or probably I can not explain it to where it is understandable In other words the radius arm of my truck is not as tall as the one I took it of does this make sense.
Ah, $45 is a good deal. Beats the hell outta $242.
Can ya do me a favor? Please use punctuation (periods). It's hard to parse your sentences. Thanks.
Back to the topic... I think I understand what you're describing.... then you'll have to get radius arms with the notch. Sway bar equipped I-beams and C-brackets sometimes use a thick flat washer btwn the lower flange of the C-bracket and the lower flange of the radius arm.
Sorry for the grammar, I will try my best wen I type.
Like you said back to the topic,
My other option is the rs a van that has what looks like the other bar you have in the pictures you posted earlier where the brackets clamp around the I beam, but they are on a van.
The other thing is it has a strap in the front of the chassis to create a bridge and this is where the bar shackles are mounted, I guess because the bar is not wide enough to be mounted to the chassis ends.
I think this one would work better for my application, guess I just have to take a tape measure and measure everything and go from there thank for you patience and all the input.
I did a ton of research and measuring before I figured out what worked. I recall seeing that bridge setup and it may work. However and if I recall correctly, Econolines have wider frames - at least the ones I looked at. Make sure you measure your frame width before heading to the yard.
You're welcome... Post up a pic when ya get'er installed.
Hey guys back from the J/Y, here are some pics of the sway bar I found. also some pics of fabrication, to make the clamp brackets stronger, I had some flat stock 2"wide x 1/2" thick
that I'll be using for the brackets.
I will be cleaning all parts for paint before install.
I will post more pics when its installed.
HIO this is the one from the van, I measured the chassis from the van and it was about 39" inches from outside to outside,that's why it had the bridge because the bar is not wide enough to mount on the chassis.
My truck is 34"inches so I don't need the bridge, the bar is wide enough to mount on mine.
Can you explain about the stiffeners,or are you referring to just put the "U" bolt from the bottom up so the plate is at the top of I beam, I can not picture what you are suggesting thanks.
The U-bolts have to be mounted with the threaded ends pointing down. There is no clearance to have the plates on top..
Lemme clarify....I suggest welding sideplates on the long sides to the plates ya made for extra stiffness. Even though it's 1/2-inch thick, one of the plates I have was slightly bent. Plus, the sideplates can act as skids to protect the threads (which are pointing down).
Here's a pic of what I mean using a wood scrap. After much thought, 1/2-inch thick bar seems to have enough mass to avoid bending. I looked at the bracket pictured below and it's only 1/4-inch thick.
Welder?.. Teach yourself! I have a Miller 140 for small projects and am looking to step up to a Miller 211 in the near future.
I agree with you 1/2" should be ok, the ones that I'm replacing are 3/8" and they are pretty flat so 1/2" should be fine, but thanks for the picture, sorry I put you to work because of my lack of imagination.
