Bucket Seats
Old May 8, 2003 | 09:38 PM
95_Ford XL's Avatar
95_Ford XL
Bucket Seats
I found some leather/power seats out of a bronco in the junkyard and I was wondering will they fit in my 95 F-150? Thanks Mike
Old May 8, 2003 | 09:55 PM
steve83's Avatar
steve83
Bucket Seats
They'll fit fine, but don't try to recline...
Old May 8, 2003 | 10:03 PM
95_Ford XL's Avatar
95_Ford XL
Bucket Seats
HAHA I know what ya mean steve....you know if it will be pretty much a direct bolt in, I belive its a 96 Bronco?
Old May 8, 2003 | 10:24 PM
steve83's Avatar
steve83
Bucket Seats
All you'll have to do is cut the holes in the floor covers and remove the rubber plugs from the mounting holes in the floor. (Put them back into the bench holes.) You should get the floor studs from the donor Bronco to put into your floor, or you might be able to use your bench bolts. The unused floor holes aren't threaded, so expect some effort when starting the bolts - Anti-Seize Lubricant will help. You'll also need to run a small power wire for the lumbar pumps. That's something else I'd scavenge from the donor.
