Electrical help please
Old Jul 5, 2012 | 04:12 PM
Usaman's Avatar
Usaman
Hooking up a Hydrogen generator and since it's gas is very explosive, I only want it to operate when the engine is running. Lord knows I might have a senior moment let alone my wife or kids decide to take it for a spin. I thought of splicing into one of the alternator wires but I would be happier with a fuse block connection. Would anyone know which fuse I can tap? God bless this bikini weather!!
Old Jul 5, 2012 | 05:12 PM
madpogue's Avatar
madpogue
There are no fuses that are energized based on whether the engine is running. Only whether the key is in the ACC or RUN position or not. You'd have to devise some trigger off the CPS or tachometer feed, or the alternator output as you say. Or you _might_ possibly be able to use the circuit for the oil pressure "gauge" on the dash. It's a glorified idiot light; the "sender" is really just a switch that opens/closes based on a minimum oil pressure.
What about just a manual kill switch in the dash?
Old Jul 5, 2012 | 05:25 PM
bad12jr's Avatar
bad12jr
Hobbs oil psi switch.
Old Jul 5, 2012 | 05:56 PM
Usaman's Avatar
Usaman
Trying to upload the shematic...
Old Jul 5, 2012 | 06:46 PM
Usaman's Avatar
Usaman
I'm thinking about maxi fuse 17. The hazard of connecting to a line which can be energized through ACC or Run would be the generation of H gas being produced with nowhere to go. A cigarette or engine ignition would be a fatal surprise. I kinda like the oil-dash guage but have no idea concerning the Hobbs oil psi switch. If anything I guess I could probe the fuses in the run position and look for an open line.
Old Jul 5, 2012 | 07:25 PM
madpogue's Avatar
madpogue
I _think_ maxifuse 17 is still gonna be energized with the key in RUN, engine running or not.
hindy
1997 - 2003 F150
15
Apr 16, 2019 08:00 AM
SlowLane
Electrical Systems/Wiring
Aug 18, 2018 11:01 AM
bennypapa
Sep 22, 2013 01:59 PM
jamiewashere
Jun 11, 2008 03:13 PM
hedhntr
Mar 15, 2007 02:52 PM
