Can't check timing
Old Sep 27, 2002 | 08:25 AM
shootemup's Avatar
shootemup
Can't check timing
Matt
'95 F150 Extended 4X4 5.0
I really need to check my timing but I can not find that little
single wire plug you need to remove. Can anyone give me an idea where
it is.
Old Sep 27, 2002 | 09:26 AM
wbw189's Avatar
wbw189
Can't check timing
Hey Matt,
On my 1994, the little plug is under the hood on the drivers side inner fender, right near the hood's hinge. The plug and the little wire you mentioned are right next to each other. I also found a better example to do the testing and code reference at BAT auto technical website. The address is www.batauto.com. I hope this helps out, it did for me!:-)
Good Luck,
Ben
Old Sep 27, 2002 | 09:44 AM
DoubleA's Avatar
DoubleA
Can't check timing
