Muffler explosion
Old Jul 22, 2012 | 10:45 PM
Rogue427's Avatar
Rogue427
Happened to me one night plowing snow. 2AM. and poor Timmy stuck in the icy ditch. 400 wound tight and BAM!!!!! Oilpump locked up.
Old Jul 23, 2012 | 07:22 AM
1968 F100 Ranger's Avatar
1968 F100 Ranger
Im starting to see this happens more than I thought.
Old Jul 27, 2012 | 03:03 AM
Thipdar's Avatar
Thipdar
That explosion is SUPPOSED to happen INSIDE the engine... to push the pistons...
Old Jul 27, 2012 | 07:39 AM
1968 F100 Ranger
I just ordered a Fuel Pump Regulator and Pressure Gauge. Thinking the electric pump is putting out too much pressure. We will see if that helps. I still haven't fixed the exhaust. Wee bit loud right now...
Old Jul 27, 2012 | 07:52 AM
Gouge Eye's Avatar
Gouge Eye
yea..... I always thought it was cool as all getout..... had a ... ahhhh 72 other truck with a )350( stock 2 into 1 system...... usta live on the "southside" of Ft Worth.... get it up to 40-50mph, kill the ignition for 3-4 seconds, then just turn it back to the "run "position.... BAM!!!!! sounds just like a double barrel 12... shoulda seen em scratchin and fetchin, jumpin behind bushes, lockin down the brakes...lol. Truck did that its whole life.... loved it.... ahhh ... to be young and dum again.....
GE
Old Jan 22, 2015 | 09:02 PM
69issofine's Avatar
69issofine
light travels faster than sound,that is why people appear intelligent until you hear them.
Old Jan 22, 2015 | 09:22 PM
Ozarktraveler's Avatar
Ozarktraveler
I'm so stealing that. ;-)
Old Jan 22, 2015 | 10:23 PM
orich's Avatar
orich
Look at the date it was last post of 7/2012
Old Jan 22, 2015 | 10:40 PM
gangstakr's Avatar
gangstakr
Glad to see some of the original posters to this thread from 7/2012 are still here. Including you Orich.
Old Jan 23, 2015 | 04:18 PM
Rasputin53's Avatar
Rasputin53
Does that make 69issofine a Voodoo Priestess for resurrecting all these zombie threads?
Old Jan 23, 2015 | 04:29 PM
CougarJohn's Avatar
CougarJohn
GE
Well, if the old thread had not been brought back to life, we would have forgotten the wisdom of Gouge Eye.
Semper Fi
Old Jan 23, 2015 | 05:39 PM
JEFFFAFA's Avatar
JEFFFAFA
And what he said in post #21 is worth it. 2X, I'm So stealing that too!
Old Jan 23, 2015 | 06:21 PM
  #28
1968 F100 Ranger
I'm still here too. Still traumatized from the experience...
Old Jan 23, 2015 | 07:34 PM
  #29
CougarJohn's Avatar
CougarJohn
Ranger, I have read your symptoms and the responses of the guys. All are good. Here are a few thoughts:
You talk about backfire through the carb and a muffler explosion. You may be hanging valves. Get a can of Marvel Mystery Oil and follow directions for the crankcase and gasoline.
How much weight do you have on the chain that hangs from the ignition key? If your switch is old the dangling weight may disconnect the ignition switch intermittently.
A muffler explosion suggests a break in the ignition path that comes back to life after fuel loads in the exhaust system. The ignition switch, connections, point settings, distributor grounds are suspect.
Give a try and report back.
Old Jan 24, 2015 | 08:31 PM
  #30
1968 F100 Ranger
Thanks for the response. But it was resolved years ago. It was an electric fuel pump dumping in too much fuel. Installed a regulator. Problem solved. Thanks though.
